SOLVED Replace failed drive leads to failures
Gen8 Runner
Hello everyone,
one of my drives failed. So i ordered a new disk, insert it to the former place and started the process of resilvering.
1. Pools -> Status -> Selected the drive and chose "Replace". Inserted two times the encryption key and chose "Force"
Failure Message: "UNIQUE constraint failed: storage_encrypteddisk.encrypted_provider"
2. I wanted to follow the guidelines, for rekey the pool. Following short manual i wanted to use:
1. Encryption Rekey
2. Create Passphrase
3. Download Encrypt Key
4. Add Recovery Key
But in FreeNAS FreeNAS-11.3-U1 doesn't exist some options anymore, for example i can't see "Encryption Rekey" anymore.
When i choose the lock-symbol and do "Encryption key / Passphrase", i need to enter the admin password and the current password for the pool.
But then comes the failure "[EFAULT] Unable to delete key 1 on gptid/e152c418-8cbe-11e9-952b-000c298f5f15: geli: Cannot open gptid/e152c418-8cbe-11e9-952b-000c298f5f15: No such file or directory. "
and
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
    io_thread=False)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1077, in _call
    return await methodobj(*args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/pool.py", line 1412, in passphrase
    await self.middleware.call('disk.geli_passphrase', pool, options['passphrase'], True)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1127, in call
    app=app, pipes=pipes, job_on_progress_cb=job_on_progress_cb, io_thread=True,
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1091, in _call
    return await run_method(methodobj, *args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/disk.py", line 458, in geli_passphrase
    self.geli_delkey(dev, GELI_RECOVERY_SLOT, force=True)
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/disk.py", line 430, in geli_delkey
    raise CallError(f'Unable to delete key {slot} on {dev}: {cp.stderr.decode()}')
middlewared.service_exception.CallError: [EFAULT] Unable to delete key 1 on gptid/e152c418-8cbe-11e9-952b-000c298f5f15: geli: Cannot open gptid/e152c418-8cbe-11e9-952b-000c298f5f15: No such file or directory
The last time it worked really smooth, but this time not really. What to do next?
Update:
I just checked the gptid of the former HDD, which failed and it was e152c418-8cbe-11e9-952b-000c298f5f15. So, looks to me, like FreeNAS is trying to delete the recovery key also on this drive, but obviously, can't find it (because it is dead & removed).
Any ideas about the other questions? Especially about the four points to do (Encryption Rekey, Create Passphrase, Add recover key etc.)?
Brgds
Gen8 Runner
Gen8 Runner
Okay everyone,
it worked. Resilvering finished, then i used "Encryption Key/Passphrase" -> entered admin pwd -> entered passphrase for the pool and chose "Change passphrase". After that entered admin pwd -> "Download Encryption key".
As last job "Recovery key" -> admin pwd "Add recovery key".
On this way i got it working without failure message. So it is a bug, need to check if I still have my login data for the Bug-Tracker. That can make you sweating all night, if you don't know, if the resilvering now worked with the encryption or not.
Edit:
JIRA Ticket is opened (NAS-105605).
