Reinstalled my system onto a usb thumb drive with a view to going mirrored instead of using 2x small HDDs. Took a backup of the config, shutdown, removed the two small HDDs, replaced with USB drives, reinstalled and restored the config.
2 of the 3 zpools has come back just fine, one however is missing and refuses to import siting missing devices which as far as I can see are only the l2arc drives (which are present and correct as well!).
I'm lost on this one at the moment, afaik a pool should import without l2arc if forced, which this doesn't. All mirror drives are there and online and all i've done is reinstall and restore the config which worked perfectly before.
[root@homevmsan1] ~# zpool import
pool: VMSAN1-ZP2
state: UNAVAIL
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
see: http://illumos.org/msg/ZFS-8000-EY
VMSAN1-ZP2 UNAVAIL missing device
mirror-0 ONLINE
gptid/82c37d3c-a338-11e4-94a6-0015174b4449 ONLINE
gptid/831e2347-a338-11e4-94a6-0015174b4449 ONLINE
mirror-1 ONLINE
gptid/a7e13348-a338-11e4-94a6-0015174b4449 ONLINE
gptid/a845d339-a338-11e4-94a6-0015174b4449 ONLINE
mirror-2 ONLINE
gptid/ef089139-a338-11e4-94a6-0015174b4449 ONLINE
gptid/ef695312-a338-11e4-94a6-0015174b4449 ONLINE
cache
gptid/4ba42e91-a339-11e4-94a6-0015174b4449
gptid/4bd38ff7-a339-11e4-94a6-0015174b4449
[root@homevmsan1] ~# gpart show
=> 34 1953525101 da0 GPT (931G)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 1949330696 2 freebsd-zfs (929G)
1953525128 7 - free - (3.5k)
=> 34 1953525101 da1 GPT (931G)
=> 34 1953525101 da2 GPT (931G)
=> 34 1953525101 da3 GPT (931G)
=> 34 1953525101 da4 GPT (931G)
=> 34 1953525101 da5 GPT (931G)
=> 34 117231341 da6 GPT (55G)
128 117231240 1 freebsd-zfs (55G)
117231368 7 - free - (3.5k)
=> 34 234441581 da7 GPT (111G)
128 234441480 1 freebsd-zfs (111G)
234441608 7 - free - (3.5k)
=> 34 1953525101 da8 GPT (931G)
=> 34 1953525101 da9 GPT (931G)
=> 34 1953522988 da10 GPT (931G)
4194432 1949328584 2 freebsd-zfs (929G)
1953523016 6 - free - (3.0k)
=> 34 1953525101 da11 GPT (931G)
=> 34 1953525101 da12 GPT (931G)
=> 34 1953525101 da13 GPT (931G)
=> 34 15633341 da14 GPT (7.5G)
34 1024 1 bios-boot (512k)
1058 6 - free - (3.0k)
1064 15632304 2 freebsd-zfs (7.5G)
15633368 7 - free - (3.5k)
=> 34 1250263661 ada0 GPT (596G)
34 222 - free - (111k)
256 1250247055 1 !6a898cc3-1dd2-11b2-99a6-080020736631 (596G)
1250247311 16384 9 !6a945a3b-1dd2-11b2-99a6-080020736631 (8.0M)
=> 34 1250263661 ada1 GPT (596G)
=> 34 1250263661 ada2 GPT (596G)
=> 34 1250263661 ada3 GPT (596G)
=> 34 117231341 da15 GPT (55G)
=> 34 117231341 da16 GPT (55G)
gptid/aea1741c-a3fc-11e4-94a6-0015174b4449 N/A da0p2 gptid/aefd2527-a3fc-11e4-94a6-0015174b4449 N/A da1p2 gptid/f779086d-a3fc-11e4-94a6-0015174b4449 N/A da2p2 gptid/f7d3e7ea-a3fc-11e4-94a6-0015174b4449 N/A da3p2 gptid/310f3342-a3fd-11e4-94a6-0015174b4449 N/A da4p2 gptid/316c4492-a3fd-11e4-94a6-0015174b4449 N/A da5p2 gptid/af5e6eb4-a3fc-11e4-94a6-0015174b4449 N/A da6p1 gptid/af35fbb6-a3fc-11e4-94a6-0015174b4449 N/A da7p1 gptid/82b7cc1d-a338-11e4-94a6-0015174b4449 N/A da8p1 gptid/82c37d3c-a338-11e4-94a6-0015174b4449 N/A da8p2 gptid/831069c4-a338-11e4-94a6-0015174b4449 N/A da9p1 gptid/831e2347-a338-11e4-94a6-0015174b4449 N/A da9p2 gptid/a7cd94e7-a338-11e4-94a6-0015174b4449 N/A da10p1 gptid/a7e13348-a338-11e4-94a6-0015174b4449 N/A da10p2 gptid/a8385285-a338-11e4-94a6-0015174b4449 N/A da11p1 gptid/a845d339-a338-11e4-94a6-0015174b4449 N/A da11p2 gptid/eefe2bfd-a338-11e4-94a6-0015174b4449 N/A da12p1 gptid/ef089139-a338-11e4-94a6-0015174b4449 N/A da12p2 gptid/ef5c5812-a338-11e4-94a6-0015174b4449 N/A da13p1 gptid/ef695312-a338-11e4-94a6-0015174b4449 N/A da13p2 gptid/299c1da2-a598-11e4-81f5-0015174b4449 N/A da14p1 gptid/29a531b3-a598-11e4-81f5-0015174b4449 N/A da14p2 gptid/09d344eb-ff4c-97c2-bb4f-d2dbaa8b01f9 N/A ada0p1 gptid/0ed5952f-f6b8-b668-af24-e99a9db01049 N/A ada0p9 gptid/1ea02dbf-2b9c-42cf-e78f-8b4d71af3a27 N/A ada1p1 gptid/69776e9e-ea9e-f3ef-e5f1-e4126335a984 N/A ada1p9 gptid/538a93cc-8a20-07e3-e617-979c5e36645a N/A ada2p1 gptid/3ba934f7-3c8b-6dec-d28a-d5683413437b N/A ada2p9 gptid/669592af-d347-b4ce-bc9a-b96761158351 N/A ada3p1 gptid/7755647f-dd1b-a9c6-d515-9712b034ab4e N/A ada3p9 gptid/4bd38ff7-a339-11e4-94a6-0015174b4449 N/A da15p1 gptid/4ba42e91-a339-11e4-94a6-0015174b4449 N/A da16p1
