I'm rather new to FreeNAS (and the BSDs) and i'm trying to reduce the power consumption. It's a 4x drive home server which sits idle most of the day. It draws 120 watts, continually, and does not seem to lower the load at all. I've spent quite a bit of time looking for answers, so I apologize if I missed an obvious (RTFM!) answer. I am measuring the power consumption with a Kill-a-watt meter, fwiw.
The montherboard's settings could be responsible but I have them set for as power-efficient as I can. That includes the AMD Cool n Quiet.
Within FreeNAS Powerd is enabled (I see no options to set, just an on/off). The disks are spinning down.
I've tried adding sysctl settings, guessing at what it should be, with no luck. the sysctl command shows the 3 CPUs with a supposed state of "C1" but it should support C2, C3, so I think that's the issue (but may be wrong here... i'm a n00b)
CPU: AMD A6-3500 APU with AMD Radeon 6530 HD Graphics 2.1/2.4GHz Socket FM1 65W Triple-Core
Board: MSI A75MA-P35
Here are some settings for detail: sysctl -a |grep "dev.cpu"
dev.cpu.0.%desc: ACPI CPU
dev.cpu.0.%driver: cpu
dev.cpu.0.%location: handle=\_PR_.P000
dev.cpu.0.%pnpinfo: _HID=none _UID=0
dev.cpu.0.%parent: acpi0
dev.cpu.0.freq: 400
dev.cpu.0.freq_levels: 2100/18760 1900/16200 1662/14175 1600/13905 1400/12127 12 25/10611 1200/10687 1050/9351 1000/9020 875/7892 800/7277 700/6367 600/5457 500/ 4548 400/3638 300/2728 200/1819 100/909
dev.cpu.0.cx_supported: C1/100
dev.cpu.0.cx_lowest: C1
dev.cpu.0.cx_usage: 100.00% last 369us
dev.cpu.1.%desc: ACPI CPU
dev.cpu.1.%driver: cpu
dev.cpu.1.%location: handle=\_PR_.P001
dev.cpu.1.%pnpinfo: _HID=none _UID=0
dev.cpu.1.%parent: acpi0
dev.cpu.1.cx_supported: C1/100
dev.cpu.1.cx_lowest: C1
dev.cpu.1.cx_usage: 100.00% last 276us
dev.cpu.2.%desc: ACPI CPU
dev.cpu.2.%driver: cpu
dev.cpu.2.%location: handle=\_PR_.P002
dev.cpu.2.%pnpinfo: _HID=none _UID=0
dev.cpu.2.%parent: acpi0
dev.cpu.2.cx_supported: C1/100
dev.cpu.2.cx_lowest: C1
dev.cpu.2.cx_usage: 100.00% last 115us
dev.cpufreq.0.%driver: cpufreq
dev.cpufreq.0.%parent: cpu0
dev.cpu.0.freq: 400
