I've had a working FreeNAS system for a 1+ years. Upgraded to 9.3, everything working great. Due to some power issues my machine fickered off and on a bunch. Now the USB boot drive I was using appears to be hosed....the system will boot up to a point (just past networking) and eventually turn off.
To test hardware vs software, I used a fresh install on a new USB drive and the system is fine.
I'd like to understand what process I might go through to recover the configuration from the old USB (if its possible). I can use the old USB to boot to single user mode fine and can see the configuration db on /data. However, I can't quite piece together the steps to get that file into the fresh install. Would love a suggested set of steps, other ideas on how to recover.
thanks
and yes- I've learned my lesson- mirrored USB boot drives.
thanks
