Reconfiguration question
I have kind of figured out my final deployment. Currently have 2-4TB drives mirrored, with Static IP, and Owncloud. (Accessed via VPN, not internet facing).
I decided to buy a third 4TB WD Red drive.
My question is can I change the config without reinstalling the whole thing? Reinstalling the whole thing would likely take a whopping 20 minutes however it is just like I want it. Changing the pool without changing everything else would be awesome.
m0nkey_
If you want to use RAIDZ1 with three drives, you will need to rebuild your pool from scratch. If you want a three drive mirror, search the forums. Plenty of how-to's on this subject.
ovizii
but at least you can export your config and reimport it again after you've done what you need to do to your pool.
