SOLVED Reclaiming HDDs
Juvx
I have 6 x 4TB WD Reds that i want to repurpose for a differant project. Whats the best way to wipe ZFS from them and use them in a windows enviorment? All data on them is backed up so im not worried about loosing it, i want to use them for a differant windows server and a faster DAS solution.
I'll still have my FreeNAS server as well.
melloa
delete all and recreate with gparted always worked for me.
depasseg
FreeNAS Replicant
Just let windows format them. If you are paranoid, and these 6 disks are the only disks in a pool, then when you "detach" the pool, you can choose to destroy the data on them.
