Realtek RTL8125 2.5Gbps Ethernet
AlexMata
I can confirm that on TrueNAS SCALE it works without any issue. I don't know if on TrueNAS CORE you still need to do any manual configuration to make it work.
cap
Unfortunately, ASPM is disabled in TrueNAS Scale for the Realtek NIC. This prevents deep c-states and the whole system consumes more power.
admin@truenas[~]$ sudo lspci -vv | awk '/ASPM/{print $0}' RS= | grep --color -P '(^[a-z0-9:.]+|ASPM |Disabled;|Enabled;)'
[sudo] password for admin:
00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 05) (prog-if 00 [Normal decode])
                LnkCap: Port #5, Speed 16GT/s, Width x4, ASPM L1, Exit Latency L1 <16us
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes, Disabled- CommClk+
00:1c.0 PCI bridge: Intel Corporation Device 7a38 (rev 11) (prog-if 00 [Normal decode])
                LnkCap: Port #1, Speed 8GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
                LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes, Disabled- CommClk-
00:1c.2 PCI bridge: Intel Corporation Device 7a3a (rev 11) (prog-if 00 [Normal decode])
                LnkCap: Port #3, Speed 8GT/s, Width x1, ASPM L1, Exit Latency L1 <64us
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 (prog-if 02 [NVM Express])
pcilib: sysfs_read_vpd: read failed: No such device
                LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 <64us
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
In Unraid and the current beta of Fedora, however, ASPM runs with the Realtek NIC.
Before installing Scale, the following message was displayed:
r8169 0000:03:00.0: Unable to load firmware rtl_nic/rtl8125b.s.fw (-2)
I don't understand that. The driver is included in the kernel.
admin@truenas[~]$ lspci -nnk | grep -iA2 net
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
        Subsystem: Gigabyte Technology Co., Ltd RTL8125 2.5GbE Controller [1458:e000]
        Kernel driver in use: r8169
How do I get APSM to run on the Realtek NIC?
EDIT:
Just realized that this is an old thread: https://www.truenas.com/community/threads/aspm-and-rtl8125-2-5gbe.113940/
cap
I managed to activate ASPM manually as root:
echo 1 > /sys/bus/pci/devices/0000:03:00.0/link/l1_aspm
Edit:
sudo sh -c "echo 1 > /sys/bus/pci/devices/0000:03:00.0/link/l1_aspm"
