Hi
I'd like to build as higher density NAS box for low reasonable cost as possible.
Found a case that takes 13 x HDD so looking at 30TB+
Do I really need 32GB of RAM for this?
As per section 1.1.2 of User Guide -
1.1.2 RAM
The best way to get the most out of your FreeNAS™ system is to install as much RAM as possible. If your RAM is limited, consider using UFS until you can afford better hardware. ZFS typically requires a minimum of 6 GB of RAM in order to provide good performance; in practical terms (what you can actually install), this means that the minimum is really 8 GB. The more RAM, the better the performance, and the Forums provide anecdotal evidence from users on how much performance is gained by adding more RAM. For systems with large disk capacity (greater than 6 TB), a general rule of thumb is 1GB of RAM for every 1TB of storage.
1.1.2 RAM
