re0: PHY read failed
zevoman
I upgraded to 8.0.4 several weeks ago from 8.0.2. Since that time, the server has crashed with this message printed repeating over and over again. It used to only crash every 2 weeks or so, then 1 week, everyday, and now several times a day. When I manually reboot, everything seems to check out fine until I can no longer access my data, in which case I check the server and it displays that message. Hard to know where to look for a problem! Is it a hardware failure? Any help would be appreciated!
survive
Behold the Wumpus
Hi zevoman,
My guess is that your NIC is going\has gone bad.
If you can, install another NIC and disable the on-board one in the BIOS. It might also be worth trying out something like "Puppy Linux" (a run-from-CD-ROM distro) and see if the NIC works better\at all.
-Will
zevoman
Thanks for the reply! I was wondering if the NIC might be failing. I've got a Ubuntu Live CD I'll pop in and see how things run. Worst case, I'll disable the on-board NIC (which I am currently using) and plop in a decided card instead. Standby!
