Thanks for taking a look.
This is all a physical system. Two of those devices are my external usb drives, the other is the flash drive freenas is installed to. Not sure why they are not showing correctly.
Biostar Hi-Fi A85W
AMD A10-5700
Memory G.SKILL Ripjaws Series Model F3-8500CL7D-8GBRL 2x 4GB
4x 3TB Western Digital Red
4x 1TB Seagate somethings.
I recently added the iSCSI pool, i could possibly export that and try re adding my data pool to see if that helps any. I'm looking to add 16gb ram, or replace current with 16gb.
The "data" pool is on ada 4-7, here is the smart info
[root@fileserver] ~# smartctl -q noserial -a /dev/ada4
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red (AF)
Device Model: WDC WD30EFRX-68AX9N0
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 21 10:12:42 2013 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (41640) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 418) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 174 174 021 Pre-fail Always - 6258
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 39
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 6902
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 38
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 28
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 10
194 Temperature_Celsius 0x0022 120 111 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 6427 -
# 2 Extended offline Completed without error 00% 5726 -
# 3 Extended offline Completed without error 00% 4965 -
# 4 Extended offline Completed without error 00% 4221 -
# 5 Extended offline Completed without error 00% 3524 -
# 6 Extended offline Completed without error 00% 2781 -
# 7 Extended offline Completed without error 00% 2062 -
# 8 Extended offline Completed without error 00% 1319 -
# 9 Extended offline Completed without error 00% 648 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@fileserver] ~# smartctl -q noserial -a /dev/ada5
Local Time is: Mon Oct 21 10:13:09 2013 EDT
was never started.
been run.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 170 169 021 Pre-fail Always - 6483
194 Temperature_Celsius 0x0022 122 113 000 Old_age Always - 28
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@fileserver] ~# smartctl -q noserial -a /dev/ada6
Local Time is: Mon Oct 21 10:13:29 2013 EDT
was never started.
been run.
data collection: (39540) seconds.
command.
power-saving mode.
recommended polling time: ( 397) minutes.
3 Spin_Up_Time 0x0027 179 178 021 Pre-fail Always - 6041
194 Temperature_Celsius 0x0022 122 114 000 Old_age Always - 28
No Errors Logged
# 2 Extended offline Completed without error 00% 5725 -
# 3 Extended offline Completed without error 00% 4964 -
# 6 Extended offline Completed without error 00% 2780 -
# 7 Extended offline Completed without error 00% 2061 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@fileserver] ~# smartctl -q noserial -a /dev/ada7
Local Time is: Mon Oct 21 10:13:44 2013 EDT
was never started.
been run.
data collection: (39900) seconds.
command.
power-saving mode.
recommended polling time: ( 400) minutes.
3 Spin_Up_Time 0x0027 179 178 021 Pre-fail Always - 6033
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 38
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 37
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 27
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The only thing I've attempted from command line thus far was "zpool import Data", and the system hung there, after about 1 hour became unresponsive and was still the same 8 hours later. After a power cycle it was as if i never ran that command.
if i did "zpool import Data Tank", that imports it and then rename to Tank which would require it to successfully import right?
