RAIDZ reads are slower than writes
fcueto
Hi there,
I installed freenas a few days ago.
My hardware is as follow:
- HP Microserver gen 8
- upgraded CPU Intel Xeon E3-1265L V2
- 16 GB of ECC UDIMM
- 4 x 4TB seagate NAS HDD ST4000VN000
- Single RAIDZ1 pool
I have a major issue with ZFS speeds. Reads are slower than writes. I was hoping to have at least read speed = write speed....
Writes speed is ~100MB/sec:
[root@freenas] /mnt/volume1/documents# /usr/bin/time -h dd if=/dev/zero of=sometestfile bs=1024 count=300k
307200+0 records in
307200+0 records out
314572800 bytes transferred in 2.949346 secs (106658491 bytes/sec)
2.98s real 0.08s user 2.86s sys
Read speed is really slower (~67MB/sec):
[root@freenas] /mnt/volume1/documents# /usr/bin/time -h dd if=sometestfile of=/dev/zero bs=1024 count=300k
307200+0 records in
314572800 bytes transferred in 4.446092 secs (70752654 bytes/sec)
4.44s real 0.01s user 4.43s sys
I tried with higher counts to minimize the "write cache" effect but I doesn't change anything.
I checked and prefetch is enabled. I can't see where I should dig...
Can you help me please ?
Thanks
Whattteva
Not sure if this will make a difference, but I'm pretty sure you want your read destination to be /dev/null not /dev/zero.
And you want block size = 1M, not 1024.
Doing tests that actually use proper parameters would be an excellent start. ;)
fcueto
I'll give a try with both your suggestions tonight but:
  • as fas as I know, writing to /dev/zero is the same than writing to /dev/null. Extract from Wikipedia : Unlike /dev/null, /dev/zero may be used as a source, not only as a sink for data. All write operations to /dev/zero succeed with no other effects. However, /dev/null is more commonly used for this purpose.
  • I'll try with bs=1M instead of bs=1k. It probably will enhance performances, but for both read and write and I will still have write speed > read speed
I'll let you know.
One other thing I forgot to mention : compression is active on the volume (lz4)
fcueto
OK, I disabled compression on the dataset and made some new tests.
cyberjock, you were right once again :)
Write speed with bs=1M is ~247MB/sec
[root@freenas] /mnt/volume1/documents# /usr/bin/time -h dd if=/dev/zero of=sometestfile bs=1M count=10k
10240+0 records in
10240+0 records out
10737418240 bytes transferred in 41.454704 secs (259015679 bytes/sec)
41.45s real 0.00s user 2.80s sys
Read speed with bs=1M is ~500MB/sec !!!
[root@freenas] /mnt/volume1/documents# /usr/bin/time -h dd if=sometestfile of=/dev/null bs=1M count=10k
10240+0 records in
10240+0 records out
10737418240 bytes transferred in 20.348966 secs (527664074 bytes/sec)
20.38s real 0.00s user 1.39s sys
I have to say I'm pretty impressed !
Thank you all
Whattteva
Those are some killer speeds. You're running SSD array?
fcueto
No. See my config on the first post.
I think the cache is involved in these results. I have to do it again with more data.
fcueto
New tests, compression still disabled:
Write : ~249MB/sec
[root@freenas] /mnt/volume1/documents# /usr/bin/time -h dd if=/dev/zero of=sometestfile bs=1M count=100k
102400+0 records in
102400+0 records out
107374182400 bytes transferred in 410.730264 secs (261422622 bytes/sec)
6m50.73s real 0.11s user 28.12s sys
Read : ~279MB/sec
[root@freenas] /mnt/volume1/documents# /usr/bin/time -h dd if=sometestfile of=/dev/null bs=1M count=100k
102400+0 records in
107374182400 bytes transferred in 366.350479 secs (293091421 bytes/sec)
6m6.35s real 0.03s user 18.02s sys
It seems more realistic !
Well, the last test is the only test that is really worth looking at. A 4 disk RAIDZ1 with your disks would typically give 200-300MB/sec and you are pretty much right in the middle. So I'd say 'nothing is broken'.
