indivision
 - Jan 4, 2013
Hello.
I am running the latest TrueNAS Core on a 4x2TB WD Red system as a RAID10. It has been going strong for 6 years now with no drive replacements. Storage is getting a bit tight lately and redundancy isn't that critical (a remote backup system is in place). So, I'm considering migrating from the RAID10 to a RAID5 in order to gain some additional storage.
I've been reading up on what I will need to do. But, can't seem to find a tutorial or guide that completely covers these operations. So, am hoping someone here can give some advice on how best to approach this. My goal is to end up with the same drives in RAID5 instead of RAID10 without having to re-build the server from scratch.
My motherboard has 6 sata slots. I already have a spare, matching 2TB Red drive on hand and could pick up another one for this process (and might add that to the array for even more storage). But, one problem seems to be that I can't make a second RAID5 pool with only the 2 open SATA ports. I need 3 drives for that. So, not sure how to work around that? Detach one of the RAID10 drives and use that (feels a bit risky)? Maybe add some SATA ports (motherboard has a PCIE 2.0 x8 internal slot)?
As a side-consideration, I'm not really sure if I should go with RAID5 or RAIDZ1? When it comes to RAID, it seems like you can find an opinion from someone for using any level under any circumstance. It sounds like RAIDZ1 may have a few neat additional features. But, maybe doesn't perform as fast?
Any advice on how to approach this would be greatly appreciated!
