Quick question about ECC capability on my motherboard + CPU
elie
Hi, I was planning for a while now to build a FreeNAS (mainly to use as a plex server) when I do a full computer upgrade.
I was reading through my motherboard's (ASUS M4A87TD) user's manual to see that use of ECC RAM seems to be supported.
However, the CPU I am running is a AMD Phenom II X4 965 (AM3). I have not been able to find out if that CPU in particular supports ECC but I have read that most AM3+ CPU's "support" ECC.
So I would like to know if this motherboard and CPU in particular can utilise ECC's benefits.
Thanks.
Spearfoot
He of the long foot
Hi, I was planning for a while now to build a freeNAS (mainly to use as a plex server) when I do a full computer upgrade.
Thanks.
Hmmm... Yes, AMD is pretty cagey about whether or not that CPU supports ECC. Just for grins, I checked Crucial's website for your motherboard and they do indeed list some ECC RAM for it. So, while I wouldn't stake my life on it, there's a chance that CPU/motherboard combo supports ECC.
Spearfoot
He of the long foot
elie
update: I checked my MOBO's BIOS and looked online. By the looks of it, every AM3/AM3+ CPU supports ECC and every ASUS mobo for the chipset support it.
