xCatalystx
- Dec 3, 2014
hey guys quick question.....
I'm considering moving my esxi storage (at home) to my freenas box. Which of these would be the best short and long term solution.
Current storage: 6x 3tb WD RED PRO in raidz2( freenas w/ 32gb memory MAXED) + 2x 500gb crucial ssd raid1 (in esxi host)
a) use the 2x SSD in a mirror than migrate that to raid10 when I purchase 2 more drives
b) use the 2x SSD as zil/log for raidz2 storage.
c) do both a + b
It will be running mainly low usage test vm"s; however there is 2 heavy database vm which are heavily used daily for development and I use this daily for testing and dev for work.
EDIT: At this stage it would not be possible to rebuild the spinning disk pool. Im looking for a solution short term to tack on, than what i should aim for.
Any friendly advice is welcome. Thanks
c) do both a + b
