blueflavorice
- Feb 1, 2019
I don't have the big budgets some of you guys have so I'm planning on using my external SAS connection to link to a box of hard drives. I don't have an extra motherboard to use so I;m going with a barebones approach. So; does anyone have experience using a Powered Ribbon Cable to power a HP 24 Port 3GB SAS Expander card 487738-001 468405-002?
I think I have only seen reference to PCB Riser Extender Cards or the PICMG 1U Backplane with PCIe Slot. Assuming the cheaper options will work ; what are the pros and cons?
Thanks in advance.
$3.69
https://www.ebay.com/itm/PCI-E-Expr...e53c2d9c:m:mYat9RrLago_LI1C8sYuhpQ:rk:30:pf:0
vs
$4.74
https://www.ebay.com/itm/VER009C-PC...m=132532924704&_trksid=p2047675.c100005.m1851
vs
pricy @ $40
https://www.mouser.com/ProductDetail/IEI/PE-2SD1-R10?qs=BzYYIKzU6HUjefZkefWjvQ==
Thanks in advance.
$3.69
vs
$4.74
vs
pricy @ $40
