SOLVED Process mono-sgen is using 100% of my cpu
Drettemy
Hi everyone!
I have run into a problem with the sonarr plugin. When looking at the running processes on my Freenas server i see that "mono-sgen" is using 100% of my cpu at all times.
I have tried making a new jail and installed the sonarr plugin there. In the new jail "mono-sgen" uses 0% of my cpu.
As you can see in my picture, PID 57395 (Existing Sonarr) is using 100% vs the PID 56366 (New Sonarr install) that is using 0%
When disabling the existing sonarr plugin service, PID 57395 disappears from the running processes.
My cpu is a Intel Pentium G4400 and I'm using the Freenas 9.10.2-U1 build
Any help is greatly appreciated!
Drettemy
Found the issue.
I was using mono v 4, while sonarr should be running mono v 3.10.0 it seems
First i deleted mono with "pkg delete mono" in the jail it was installed
I then downloaded the latest sonarr pbi file from here and uploaded it to the jail:
http://download.freenas.org/plugins/9/x64/
