Previously 8.0-Release amd64 on HPMicroserverN36L 8GB RAM 4x2TB discs. Upgraded using CD method yesterday. System seems mostly functional and no serious errors on boot.
Since early this am, CPU has been running about 50-60% usage according to the graph, whereas on 8.0, it would sit on nearly nothing. AFP shares having trouble bringing up a directory.
top
AFP reboot:
So going to switch back to 8.0-Release. What information can I provide to help debug this?
top
last pid: 3582; load averages: 0.54, 0.68, 0.80 up 0+00:49:18 07:17:43
284 processes: 4 running, 265 sleeping, 15 waiting
CPU: 0.4% user, 0.0% nice, 17.4% system, 3.2% interrupt, 79.0% idle
Mem: 96M Active, 35M Inact, 1244M Wired, 4240K Cache, 141M Buf, 6414M Free
Swap: 8192M Total, 8192M Free
PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND
11 root 2 171 ki31 0K 32K CPU0 0 55:55 152.93% idle
0 root 164 -8 0 0K 2608K - 1 26:17 34.47% kernel
159 root 10 -8 - 0K 144K zio->i 1 9:05 12.45% zfskern
12 root 15 -60 - 0K 240K WAIT 0 3:01 5.57% intr
4 root 1 -8 - 0K 16K - 1 2:08 2.59% g_down
3 root 1 -8 - 0K 16K - 1 1:23 1.17% g_up
1774 root 6 44 0 115M 63560K uwait 1 0:11 0.00% python
7 root 1 76 - 0K 16K ccb_sc 0 0:05 0.00% xpt_thrd
1874 root 7 44 0 64020K 8188K ucond 0 0:02 0.00% collectd
3390 root 2 66 0 31496K 4416K select 0 0:01 0.00% afpd
2278 www 1 44 0 19324K 4076K kqread 1 0:01 0.00% lighttpd
2367 root 1 76 0 64096K 24448K ttyin 1 0:01 0.00% python
1515 root 1 44 0 11776K 2784K select 1 0:01 0.00% ntpd
14 root 24 -64 - 0K 384K - 0 0:01 0.00% usb
58 root 1 -8 - 0K 16K mdwait 1 0:00 0.00% md2
2913 root 1 44 0 9224K 3284K CPU1 1 0:00 0.00% top
2 root 1 -8 - 0K 16K - 0 0:00 0.00% g_event
2583 root 1 44 0 33300K 5044K select 1 0:00 0.00% sshd
AFP reboot:
Oct 5 07:14:06 microserver freenas[1774]: Executing: /usr/sbin/service netatalk restart Oct 5 07:14:06 microserver freenas: No matching processes were found Oct 5 07:14:06 microserver freenas: No matching processes were found Oct 5 07:14:06 microserver cnid_metad[3387]: Set syslog logging to level: LOG_NOTE Oct 5 07:14:06 microserver [3389]: Set syslog logging to level: LOG_NOTE Oct 5 07:14:06 microserver afpd[3390]: AFP/TCP started, advertising 192.168.0.62:548 (2.2.0) Oct 5 07:14:07 microserver freenas[1774]: Executing: /bin/pgrep -F /var/run/afpd.pid afpd Oct 5 07:14:11 microserver afpd[3390]: bind(fd, (struct sockaddr *)&address, address_length) failed: Address already in use
