Greetings,
We're using a Supermicro SSG-6048R-E1CR24L
2 x Intel(R) Xeon(R) CPU E5-2603 v4 @ 1.70GHz
64 GB RAM
SAS3 via LSI 3008 controller
8 x Seagate 3.5 HDD 6TB 7200RPM 12Gb/s SAS 128 MB Cache Internal Bare Drive ST6000NM0034
I had a drive that seemed to keep failing (I say seemed because I'm not sure if it's the controller) and I bought a replacement for it, but after following the instructions on replacing the drive, it's just giving me these errors:
sysctl kern.geom.debugflags=16
I get
These new drives are supposed to be exactly the same and as far as I can tell, they are.
If I grep dmesg I get endless errors.
So I'm stuck. Any assistance would be greatly appreciated.
64 GB RAM
- Cannot Format GPT Partition
- dd: /dev/da3: Operation not permitted
I get
[MiddlewareError: Failed to wipe da3: dd: /dev/da3: Invalid argument 1+0 records in 0+0 records out 0 bytes transferred in 0.009787 secs (0 bytes/sec) ]
videonas2# dmesg | grep da3 da3 at mpr0 bus 0 scbus0 target 19 lun 0 da3: <SEAGATE ST6000NM0034 NE02> Fixed Direct Access SPC-4 SCSI device da3: Serial Number Z4D2SN9V0000R601MG5N da3: 1200.000MB/s transfers da3: Command Queueing enabled da3: 5723166MB (11721045168 512 byte sectors) ses0: da3: Element descriptor: 'Slot11' ses0: da3: SAS Device Slot Element: 1 Phys at Slot 11 (da3:mpr0:0:19:0): READ(16). CDB: 88 00 00 00 00 02 ba a0 f4 ae 00 00 00 01 00 00 (da3:mpr0:0:19:0): CAM status: SCSI Status Error (da3:mpr0:0:19:0): SCSI status: Check Condition (da3:mpr0:0:19:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code) (da3:mpr0:0:19:0): Field Replaceable Unit: 0 (da3:mpr0:0:19:0): Descriptor 0x80: 00 00 00 00 ff 2d 00 00 00 00 00 00 00 00 (da3:mpr0:0:19:0): Error 22, Unretryable error (da3:mpr0:0:19:0): READ(16). CDB: 88 00 00 00 00 02 ba a0 f4 af 00 00 00 01 00 00 (da3:mpr0:0:19:0): CAM status: SCSI Status Error (da3:mpr0:0:19:0): SCSI status: Check Condition (da3:mpr0:0:19:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code) (da3:mpr0:0:19:0): Field Replaceable Unit: 0 (da3:mpr0:0:19:0): Descriptor 0x80: 00 00 00 00 ff 2d 00 00 00
