Okay so after doing a fresh install, I have been hitting up against numerous little problems.
First one https://forums.freenas.org/index.php?threads/zpool-import-issues.28529/ - to do with importing the zpool so its persistent between reboots. [EDIT: This has been resolved in the thread https://bugs.freenas.org/issues/8793]
Second one: https://forums.freenas.org/index.php?threads/checksum-mismatches-after-install-verification.28517/ - getting the same mismatch on the resolv.conf
Third one (and one I want fixed ASAP before I have a power cut): I had a small power cut - noticed I didn;'t getmy usual UPS ONBATT email, or when the power restored get my UPS ONLINE email. Quick check of the settings the UPS service was still on, looking at its configuration however the driver is "----------" and there is no option on the drop down menu to pick anything else. It's an APC Smart UPS, and if I remember correctly it used to have APCsmart as its driver. I turned the service off, and now it won't turn back on - so currently my UPS is useless...
Any help would be appreciated
