ghostofdeath
- May 28, 2012
Hi I got some problems here I hope you can help. First I tried to use my usb drive to boot freenas 8.0.4 x86 release as here:
http://doc.freenas.org/index.php/Burning_an_IMG_File
and everything worked fine. then I booted my pc and it kept saying this error "autosense failed" ok so I got my drive back and would try to install it again, then i realized that my drive (which was 16gb) is now 1gb! and even if I format it keeps as 1gb. So I got both problems, can I recover my drive back to its normal? (I thought it would be like windows boot installation, just using once and then delete all files) and why i was seeing this error? what's the problem?
Btw I'll try to install from usb to another usb, is there any problem with that?
I hope you answer soon!
Thanks.
Thanks.
