James Random
- Jun 22, 2014
Hi all,
I have freenas (9.2.1.5) up and running thanks to the good documentation (much better than a lot of OSS projects!) and excellent advice I have picked up from the forum. It is working well as a fileserver/backup.
I have just created a standard FreeBSD jail to use as a general purpose *nix machine. A few programs produce the error message:
shmget() failed: Function not implemented
Disabling shared memory tile transport
Looking around, a few people have had a similar problem with FreeBSD/FreeNAS (mainly when trying to run PostgreSQL, which isn't waht I am doing). One of the suggested fixes is to set security.jail.sysvipc_allowed to 1 in a sysctl. I have tried this and it doesn’t work.
There were also (conflicting) suggestions to put this in rc.conf:
jail_sysvipc_allow="YES"
I did that (by editing /conf/base/etc/rc.conf) but it didn’t fix it.
After reading this bug report (https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=173469), I changed that to:
jail_example_parameters="allow.sysvipc=1"
That doesn’t work either (which is OK, because there doesn’t seem to be a good way of making permanent changes to rc.conf).
Another suggestion was to run:
jail -m jid=3 allow.sysvipc=1
That works when I run it from the command line. So I tried putting the command in as an Init Script (with complete paths) set to run Post Init:
/usr/sbin/jail -m jid=`/usr/sbin/jls -j FreeBSD jid` allow.sysvipc=1
That doesn’t work (I guess it is getting run too early, before the jail is started, or something).
Any idea why these don't work? Any other suggestions to work around this? (This isn’t vitally important, but I have learnt a lot about FreeBSD and FreeNAS by trying to figure it out...)
