FlangeMonkey
 - Dec 6, 2012
I'm unsure if this is related to the below bug report, but I thought I'd create a new thread.
http://forums.freenas.org/threads/9-2-1-mdnsresponder-messages.18317/
I'm unable to resolve clients (can only test with Mac) through mDNS. I can however resolve freenas.local from other devices.
I'm not familiar with mDNS but I am seeing the mDNSResponder service status as:
dlavigne, suggested using onestart but I receive the message:
Any suggestions?
Edit: I'm also seeing the below when I run service -e:
[root@freenas] ~# service mdnsresponder status
Will not 'status' mdnsresponder because mdnsresponder_enable is NO
mDNSResponderPosix: You must specify a service name to register (-n) or a service file (-f).
/usr/local/etc/rc.d/mdnsresponder: WARNING: failed to start mdnsresponder
Any suggestions?
Feb 10 17:59:04 freenas root: /usr/sbin/service: WARNING: $vmware_guest__enable is not set properly - see rc.conf(5).
Feb 10 17:59:04 freenas root: /usr/sbin/service: WARNING: $warden_enable is not set properly - see rc.conf(5).
Feb 10 17:59:04 freenas root: /usr/sbin/service: WARNING: $sssd_enable is not set properly - see rc.conf(5).
Feb 10 17:59:04 freenas root: /usr/sbin/service: WARNING: $snmptrapd_enable is not set properly - see rc.conf(5).
Feb 10 17:59:04 freenas root: /usr/sbin/service: WARNING: $snmpd_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $nut_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $nut_upslog_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $nut_upsmon_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $rrdcached_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $django_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $mdnsresponder_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $git_daemon_enable is not set properly - see rc.conf(5).
Feb 10 17:59:05 freenas root: /usr/sbin/service: WARNING: $collectdmon_enable is not set properly - see rc.conf(5).
