uncarvedblock
- Mar 8, 2014
Some background:
I converted my old computer to a FreeNAS box.
Motherboard: Gigabyte GA-MA790X-UD4
Processor: Phenom II 920 quad core 2.8 GHz
Memory: 4 GB DDR2
HDDs: 2x 3 TB WD Red
Powersupply: 500W Antec Earthwatts
Videocard: Radeon HD 4870
(not really a key part of the build, but it is still installed so I can hook up a monitor and in case the system would not work headless)
I am running FreeNAS-9.2.0-RELEASE-x64 (ab098f4).
I decided to go with UFS because I did not have the ram for ZFS and I decided I did not want a raid setup to start. I had a friend warn me that he had issues keeping his raid setups running and being a noob, I just created 2 UFS volumes and set up an rsync job to copy the contents of the main disk to the second disk daily.
I named the drives Master0 and Second0.
I started getting random reboots and the system would run through a lot of checks / fixes when it rebooted. The most common message I would get was something like this:
(ada0:ahcich1:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 80 9e 40 40 00 00 00 00 00 00
(ada0:ahcich1:0:0:0): CAM status: Uncorrectable parity/CRC error
(ada0:ahcich1:0:0:0): Retrying command
Then it would usually reboot again. I would power down and a couple times I tried booting again and then it would work after a few file repairs. Unfortunately I did not record the monitor and as far as I know FreeNAS does not by default save the logs after reboots because of being installed on an usb or something. Correct me if I am wrong...
It might have been foolish but I did the following:
I removed and reconnected the sata cables in case there was a connection issue.
I did not completely understand what was discussed in another post with a similar error, where they discussed possible issues with sata cables and I figured that was pretty low risk.
http://forums.freenas.org/index.php?threads/uncorrectable-parity-crc-error.14404/page-2
Then I rebooted and it worked fine but the disk Master0 showed and error.
I though it might have been due to switching sata ports and i tried to import volume. UFS, named Master0, ada1 but I got an error, "The selected disks were not verified for this import rules."
I thought maybe if I removed the old Master0 volume entry and then tried importing it again it might work so i tried, but now I still get the same error.
Hopefully that did not screw things up more than they already were.
If I screwed up the contents of Master0 I can always copy them over from the Second0 drive, but that still will not address the Uncorrectable parity/CRC error I was getting at the start of this.
Sorry for the long post. Thanks for any help.
Memory: 4 GB DDR2
