Hi All,
New FreeNAS 11 user running amok. I was running FreeNAS 11 on 3 different machines each with 8 drives. Wanted to consolidate them into 1 machine. I went out and bought a Norco RPC-4224 (24 drive slots) and an Intel RES2SV240 expander. Supermicro LGA1150 Main Board Motherboard X10SLH-F 48gig memory
I am having problems seeing all the drives. The most I can see is 8. Not sure what else to do to get this working. Here is what I have done so far:
LSI 9211-8i is flashed for IT mode it is from one of my FreeNAS machines, it seems to be working fine. The expander is new. All new 8087 cables 1 meter in length. New case with 24 drive slots.
Tried connecting the HBA to the expander with 1 and 2 8087 cables not all drives show up but if you test each drive slot with the same drive you can see them all. At a loss on what else that I can do to make it work. Any help would be appreciated. As it sits now I don't know which way to go to fix it.
Thanks
Thanks
