Problem Loading Plugins
Bootdisk99
Just downloaded and setup a brand new TrueNAS server today 12-22-2021 using version 12.0-U7.
I have setup my pool, created an ADMIN group as well as a user account all with permissions granted.
I chose the pool to use for the jail I called STORAGE.
When I try to load the plugins from XIsystems or the community I get this error...
I can login as root or under my user account and get the same error.
Get Plugins Failed​
[EFAULT] Cmd('git') failed due to: exit code(128) cmdline: git clone -v https://github.com/freenas/iocage-ix-plugins.git /mnt/STORAGE/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git stderr: 'Cloning into '/mnt/STORAGE/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git'... fatal: unable to access 'https://github.com/freenas/iocage-ix-plugins.git/': Could not resolve host: github.com '
Anyone know why it cannot fetch these from their proper servers?
I don't know if I have something setup wrong.
Most all settings are at their default.
Thank You for your help!!
Bootdisk99
Nevermind.... Found the problem. I had a static ip address configured for the nic. I changed it in my router to reserve an address instead. Changed my server back to DHCP and now all is working well.
Thanks
ThreeDee
something you might want to consider though .. is doing manual installs instead of plugins .. much easier to maintain/keep updated
