N1k0_VE
- Mar 5, 2016
So I build my setup. I have a motherboard with 6 sata connections. I added 5 WD red drives and 1 SSD to run the freenas software. And installing the software from a USB thumb stick.
The problem I have is that one of the 5 wd red drives is not recognized by freenas.
But in the bios my 5 drives and the ssd are available. Even when installing freenas and on the drive selection screen all my 5 drives are available including the SSD. But when everything is installed and the server is running, when I open freenas on another PC in the browser and I go through the wizard it only detects 4 wd red drives and 1 SSD and not my 5th wd red. So I can't build my raid with 5 drives. any help would be appreciated. cause I'm stuck and don't know what the problem is. Also my bios is set on achi.
