Problem after Web-GUI Update FreeNAS 9.3 - Boot Problems
vanhaakonnen
Hi guys,
after upgrading via web-gui to the latest 9.3 release my system won't boot anymore.
I already tried the Fix "Workaround/Semi-Fix for Mountroot Issues with 9.3!" - without success. I have a supermicro X8SI6-F mainboard.
Do you have any idea for me?
VanHaakonnen
That looks like a corrupted zpool. The question is whether it's the boot device's zpool or your data zpool.
So I'd recommend you take a new USB stick (or hard drive that is spare) and install FreeNAS 9.3 on it and see if it boots and try to import your data pool.
gpsguy
Active Member
Did it happen right after the upgrade? If so, (and you didn't upgrade your pool), you might also try reinstalling the old version on a different boot disk and restore your old config file, assuming you have one.
Sent from my phone
vanhaakonnen
I have tried a new installation of FreeNAS on the current usb stick - without success. On a new stick everything works fine again. So cyberjock was right - the stick was faulty... :/
Thank you! :)
