Stanri010
- Apr 15, 2014
I've got a network with both PCs and Macs. I have noticed that when I have both CIFS and AFP shares enabled, my mac will take a long time (10+ seconds) to try to log into the NAS many times, it will fail. Then you would have to reclick on the icon to try to get it to log in.
When I disable CIFS and just have AFP enabled, the mac instantly picks up the NAS and logs in as if that was its internal drive.
Thus, I'm suspecting that the mac will try to log into the NAS using CIFS even if you've got both enabled. Is this true? If so, how do you tell the mac to ignore the CIFS share and only use the AFP share?
