So i had grate idea that i will try setup it by this
https://wiki.freebsd.org/TuningPowerConsumption
so i import values performance_cx_lowest, and economy_cx_lowest, to TUNABLES.
System boot but there is some trouble.:
WEB GUI - DOSNT work, in console i can see error that django.db.models.loading import cache, import Q, import Collector, import signals, sql . its quiting with ImportError: cannot import name sql:
what i try do:
I try edit /boot/loader.conf.local - i remove this lines what i added to Tunables, but its automaticaly recoverd after reboot...
I try boot from boot menu 3 unset this two values, and boot, but its same?
how can i manuly remove this lines from tunable? from wich location freenas take it and replace it ?
Starting pbid...
File "/usr/local/www/freenasUI/manage.py", line 42, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv
self.execute(*args, **options.__dict__)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 280, in execute
translation.activate('en-us')
File "/usr/local/lib/python2.7/site-packages/django/utils/translation/__init__.py", line 130, in activate
return _trans.activate(language)
File "/usr/local/lib/python2.7/site-packages/django/utils/translation/trans_real.py", line 188, in activate
_active.value = translation(language)
File "/usr/local/lib/python2.7/site-packages/django/utils/translation/trans_real.py", line 177, in translation
default_translation = _fetch(settings.LANGUAGE_CODE)
File "/usr/local/lib/python2.7/site-packages/django/utils/translation/trans_real.py", line 159, in _fetch
app = import_module(appname)
File "/usr/local/lib/python2.7/site-packages/django/utils/importlib.py", line 40, in import_module
__import__(name)
File "/usr/local/www/freenasUI/../freenasUI/api/__init__.py", line 27, in <module>
from tastypie.api import Api
File "/usr/local/lib/python2.7/site-packages/tastypie/api.py", line 8, in <module>
from tastypie.serializers import Serializer
File "/usr/local/lib/python2.7/site-packages/tastypie/serializers.py", line 9, in <module>
from django.core.serializers import json as djangojson
File "/usr/local/lib/python2.7/site-packages/django/core/serializers/__init__.py", line 22, in <module>
from django.core.serializers.base import SerializerDoesNotExist
File "/usr/local/lib/python2.7/site-packages/django/core/serializers/base.py", line 5, in <module>
from django.db import models
File "/usr/local/lib/python2.7/site-packages/django/db/models/__init__.py", line 5, in <module>
from django.db.models.query import Q
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py", line 17, in <module>
from django.db.models.deletion import Collector
File "/usr/local/lib/python2.7/site-packages/django/db/models/deletion.py", line 4, in <module>
from django.db.models import signals, sql
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Thanks Martin
