malcolmputer
- Oct 28, 2013
I have a SC846E16-R1200B chassis with the dual PWS-1K21P-1R power supplies. I currently have it loaded up with a X10SLL-F with 32GB of RAM and a E3-1241 v3. I have the full 24 bays loaded with mixed HGST HDS72202 and WD WD10EAVS drives.
My question is, my power draw from the wall is ~220W. Does that sound right? According to the 80 PLUS test report (http://www.supermicro.com/products/powersupply/80PLUS/80PLUS_PWS-1K21P-1R.pdf) I should be about 89% efficient at that range.
Is it possible to switch out the supplies in this chassis with the more efficient 920W platinum rated ones? I don't see much info in the chassis manual from supermicro, but I assume it would be ok.
