Post upgrade issues
H0mez
I upgraded to 9.1 via the GUI and since then I haven't been able to start plugins(old ones or new ones that I just installed, plex etc) or connect to the NAS via my network share over windows.
Is there some config I need to change/update after the upgrade that I missed?
warri
For old jails you have to execute the migrate jail script: http://doc.freenas.org/index.php/Migrating_an_8.x_Jail
Your network configuration shouldn't be affected by an upgrade, maybe except if it pointed to folders in the jail? Not quite sure, since I'm not using jails personally.
H0mez
ya I think im just going to remove all that stuff. I'm not even worried about that part really, its more that I cant even access the box through windows network(going into the shared folders etc). Because thats not a plugin.
