hungarianhc
- Mar 11, 2014
I'm relatively new to scripting, especially with FreeBSD. I'm not sure where to put all the files, what good start / stop conventions are.
I installed Btsync in a jail, and I wrote a startup script for it. It seems to get the job done, but I'm sure there are ways to improve it / make it more correct. I'm hoping we can improve it, and then I'll publish a tutorial for others. Thanks!
Script:
Script:
#!/bin/sh
# $FreeBSD$
# PROVIDE: Bittorrent Sync
# REQUIRE: LOGIN FILESYSTEMS
# KEYWORD: shutdown
. /etc/rc.subr
name=btsync
rcvar=btsync_enable
extra_commands=status
start_cmd="${name}_start"
stop_cmd="${name}_stop"
status_cmd="${name}_status"
pidfile=/var/run/btsync/btsync.pid
load_rc_config $name
: ${btsync_enable:=no}
: ${btsync_msg="Nothing started."}
: ${btsync_user="btsync"}
: ${btsync_group="btsync"}
btsync_start()
echo "Starting BTSync..."
/usr/local/sbin/btsync --webui.listen 0.0.0.0:8888
echo $! > pidfile
btsync_stop()
echo "Killing all btsync processes..."
killall -e btsync
btsync_status()
echo "Checking the status, sir!"
run_rc_command "$1"
