9C1 Newbee
- Oct 9, 2012
I have had great luck the last few weeks with my new build.
SUPERMICRO MBD-X9SCM-F-O LGA
Xeon E3-1230V2
32G ECC Ram
Flashed M1015
6 3TB WD Green in raidz2
1 2TB WD Green for jail duty
About two weeks ago, I enabled the auto tune function. Other than that I have not molested the machine up to this point.
2 days ago I got an email from the system that a drive could not be opened. The drive did not show up in the GUI. I rebooted the system. The drive came back online and seemed to be working.
A different drive dropped out of the array an hour later. I rebooted and things seemed fine again.
I started a scrub of the pool.
I have never seen the scrub repair anything before. Something is up.
I have searched. I just don't know enough about shell commands to do anything. What should would you do next?
I also have a brand new 3TB Green here ready to roll if needed.
Xeon E3-1230V2
32G ECC Ram
Flashed M1015
pool: BigPool
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://www.sun.com/msg/ZFS-8000-9P
scan: scrub repaired 3.85M in 6h23m with 0 errors on Sun May 19 05:26:12 2013
NAME STATE READ WRITE CKS
UM
BigPool ONLINE 0 0
0
raidz2-0 ONLINE 0 0
0
gptid/f849925f-a41b-11e2-8c93-002590a969a1 ONLINE 0 0
0
gptid/f9328a49-a41b-11e2-8c93-002590a969a1 ONLINE 0 0
0
gptid/fa072ee7-a41b-11e2-8c93-002590a969a1 ONLINE 0 0
0
gptid/fae46be7-a41b-11e2-8c93-002590a969a1 ONLINE 0 0
0
gptid/fbba45b8-a41b-11e2-8c93-002590a969a1 ONLINE 0 0 9
85
gptid/fc945db6-a41b-11e2-8c93-002590a969a1 ONLINE 0 0
0
errors: No known data errors
pool: Jacuzzi
state: ONLINE
scan: scrub repaired 0 in 2h26m with 0 errors on Sun May 19 02:26:28 2013
NAME STATE READ WRITE CKSUM
Jacuzzi ONLINE 0 0 0
gptid/9a2697ea-a4b9-11e2-8b46-002590a969a1 ONLINE 0 0 0
errors: No known data errors I have never seen the scrub repair anything before. Something is up.
