POS-PIB75CX REV 1.02B positive motherboard
I am not able to use freenas on this motherboard.
It always hangs on the screen below.
The installation process proceeds without errors.
Hugs
Samuel Tai
Which version of FreeNAS did you install? This looks like it's trying to mount a UFS RAM disk image. Current versions mount a ZFS partition directly.
Version: FreeNAS 11.3-U3.2
Used rufus-3.11p.
I have already installed both on a 32Gb sandisk pendrive and on a 500gb HDD.
The two hang on the same screen.
Samuel Tai
Rufus 3.11 for some reason doesn't reliably write the FreeNAS ISO to USB. I tried it myself just now and got a non-working USB thumb drive. Some folks claim Rufus 1.3 works better.
Have you tired Etcher?
pschatz100
I like Win32DiskImager. Not as many options as the other tools, but it always works for me. I also hear Etcher recommended a lot, but I have not used it personally.
I quit using Rufus.
