I recently replaced all 8 drives in my server with new drives. (4TB HGST to shucked 10TB Seagate Barracuda Pros).
I actually had to rebuild the entire Pool to change the block size to 4k, then replicated to the new drives. I did this using two chassis and two LSI cards due to not having enough space in my primary chassis
I did have some weird device reset errors when I had the drives split up, I attributed this to the precarious nature of the setup, and the errors were on my backup chassis.
Completed the transfer and put the new drives into the primary chassis. Everything was fine until last week when I got a notification the Pool was degraded.
DA7 was showing some read/write errors and degraded, I power cycled the server and re-seated the drive, it booted up fine and the Pool was normal again.
Fast forward to yesterday when I received a notification the Pool was degraded again.
DA7 and DA5 both have read/write errors.
I have SMART tests scheduled but received no SMART warnings so I checked for errors, here is the output:
DA5
DA7
Disk errors reported in FreeNAS:
I'm no expert with SMART data but I don't see any read/write errors present? What would cause the ZFS to see read/write errors? The LSI card, or am I missing something perhaps? All the new drives are on the same LSI card in IT mode that was working with the old drives.
Thanks
DA5
  1 Raw_Read_Error_Rate     0x000f   076   064   044    Pre-fail  Always       -       44632200
  3 Spin_Up_Time            0x0003   090   090   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       21
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   084   060   045    Pre-fail  Always       -       234027207
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1800 (122 111 0)
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       20
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   069   069   000    Old_age   Always       -       31
190 Airflow_Temperature_Cel 0x0022   074   047   040    Old_age   Always       -       26 (Min/Max 24/28)
191 G-Sense_Error_Rate      0x0032   093   093   000    Old_age   Always       -       15492
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       13
193 Load_Cycle_Count        0x0032   095   095   000    Old_age   Always       -       11551
194 Temperature_Celsius     0x0022   026   053   000    Old_age   Always       -       26 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   009   002   000    Old_age   Always       -       44632200
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       880 (239 115 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       35954624018
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       40571654043
DA7
  1 Raw_Read_Error_Rate     0x000f   076   064   044    Pre-fail  Always       -       38111312
  3 Spin_Up_Time            0x0003   091   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       14
  7 Seek_Error_Rate         0x000f   081   060   045    Pre-fail  Always       -       122729332
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       571 (199 172 0)
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       11
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   081   081   000    Old_age   Always       -       19
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1756
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       2
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1644
195 Hardware_ECC_Recovered  0x001a   009   001   000    Old_age   Always       -       38111312
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       483 (175 26 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       28520739476
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       32704312746
Thanks
