RamboFR05TY
- Jan 3, 2019
Hi Guys,
I would like to ask for help as i am out of ideas
Current Setup i5 16GB ram with 2x2TB 2x1TB 500GB OS drive
I Cant load available plugins aswell as i cannot update
Plugin Error:
Using Public DNS and resolving domains works fine like google.co.za or other domains and pinging works perfectly fine aswell both in jails and out of jails it is working correctly able to resolve domain and ping IP/domains successfully with no issue via shell
TIA
Regards
RamboFR05TY
Plugin Error:
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 816, in get_plugin_version
'iocage_rpkgdict')
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 100, in call_sync
return self.client.call(method, *params, timeout=timeout, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 451, in call
raise c.py_exception
KeyError: 'iocage_rpkgdict'
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
OSError: [Errno 65] No route to host
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.6/http/client.py", line 964, in send
self.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 166, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x80e489518>: Failed to establish a new connection: [Errno 65] No route to host
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='pkg.cdn.trueos.org', port=80): Max retries exceeded with url: /iocage/11.2-RELEASE/All (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x80e489518>: Failed to establish a new connection: [Errno 65] No route to host',))
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 485, in list_resource
pv = self.get_plugin_version(plugin[2])
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 822, in get_plugin_version
f'http://pkg.cdn.trueos.org/iocage/{branch}/All')
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='pkg.cdn.trueos.org', port=80): Max retries exceeded with url: /iocage/11.2-RELEASE/All (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x80e489518>: Failed to establish a new connection: [Errno 65] No route to host',))
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1109, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1046, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1073, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 989, in run_in_executor
requests.exceptions.ConnectionError: None: Max retries exceeded with url: /iocage/11.2-RELEASE/All (Caused by None)Using Public DNS and resolving domains works fine like google.co.za or other domains and pinging works perfectly fine aswell both in jails and out of jails it is working correctly able to resolve domain and ping IP/domains successfully with no issue via shell
TIA
Regards
RamboFR05TY
