sdgenxr
- Sep 4, 2014
OK, I'm about over with FreeNAS. When it works, it works fantastically! When it doesn't, I'm pulling my hair out for days/weeks and giving up on it completely. After the update that killed SMB v1, I lost access to my shares via browsing by hostname (\\server), and could not connect via IPMI (separate issue). Over the past few weeks, I've needed files of the server and was finally able to connect via IPMI and browse files via IP address (\\192.168.1.100). After a few updates, reading many threads about hostname issues, I was able to view my shares via hostname (\\server) briefly. Now I cannot browse via hostname again and get the below error when trying to browse available plugins.
Combined with this challenge and the difficulty in setting up users inside of jails to read/write files to the shared folders, I'm really at my wits end with FreeNAS and don't want to be. Any advice, guidance to ease me back from the edge would be greatly appreciated.
<urlopen error [Errno 8] hostname nor servname provided, or not known>
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/urllib/request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.6/http/client.py", line 964, in send
self.connect()
File "/usr/local/lib/python3.6/http/client.py", line 1392, in connect
super().connect()
File "/usr/local/lib/python3.6/http/client.py", line 936, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/local/lib/python3.6/socket.py", line 704, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 8] hostname nor servname provided, or not known
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 643, in fetch_plugin_index
self.__clone_repo(git_server, git_working_dir)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 1255, in __clone_repo
porcelain.pull(destination, repo_url, errstream=devnull)
File "/usr/local/lib/python3.6/site-packages/dulwich/porcelain.py", line 818, in pull
path, r, progress=errstream.write, determine_wants=determine_wants)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 363, in fetch
progress)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 1398, in fetch_pack
b"git-upload-pack", url)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 1282, in _discover_references
resp, read = self._http_request(url, headers, allow_compression=True)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 1261, in _http_request
resp = self.opener.open(req)
File "/usr/local/lib/python3.6/urllib/request.py", line 526, in open
response = self._open(req, data)
File "/usr/local/lib/python3.6/urllib/request.py", line 544, in _open
'_open', req)
File "/usr/local/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.6/urllib/request.py", line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/local/lib/python3.6/urllib/request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 8] hostname nor servname provided, or not known>
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 530, in list_resource
header=False)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 914, in fetch
icon=True, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 650, in fetch_plugin_index
_callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 90, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: <urlopen error [Errno 8] hostname nor servname provided, or not known>
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1141, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1078, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
