Plugins installed in a different storage pool don't restart when system restarts
vpgc50
Hi.
Not sure if this is the right place to post this question, I was unable to find something similar in the forums / google.
Currently, I have two different HDDs/pool in my system. I have 3 plugins/jails installed on one pool and 1 plugin/jail on the other. When I restart the system, only the plugins that are on the selected pool restart while the ones located on the other pool don't. I attached a screenshot of what I mean by "selected pool". Each jail is set to auto-start on boot. Is this normal?
Currently running TrueNAS 12 Beta.
hello is there any solution for this ?
Run all of your jails on a single pool as per the design of iocage.
Mount storage for config and data into your jails from any pool you like (which is probably what was originally wanted... 4 years ago by the OP).
