I tried this so many times with several different setups but I always end up at the same point -> as soon as I start openvpn in my jail, I can not ping to anything and the webgui from my plugin (transmission) is also not reachable. As soon as I stop openvpn everything works.
I am running TrueNAS-13.0-U6.1.
This is what I did:
1. I installed the transmission plugin via TrueNAS WebGUI and the only setting I changed in the installation was `allow_tun` checkmark.
2. I installed openvpn and configured it
3. start openvpn
When looking at the logs it seems that openvpn runs just fine:
I assume that there is some jail/network setting I am missing but I have no clue what it is....
I added screenshots of my jail setting:
This is what I did:
3. start openvpn
Apr 3 18:18:40 transmission openvpn[2810]: OpenVPN 2.6.9 amd64-portbld-freebsd13.2 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] Apr 3 18:18:40 transmission openvpn[2810]: library versions: OpenSSL 1.1.1t-freebsd 7 Feb 2023, LZO 2.10 Apr 3 18:18:40 transmission openvpn[2811]: TCP/UDP: Preserving recently used remote address: [AF_INET]193.187.88.222:443 Apr 3 18:18:40 transmission openvpn[2811]: Socket Buffers: R=[65536->65536] S=[32768->32768] Apr 3 18:18:40 transmission openvpn[2811]: Attempting to establish TCP connection with [AF_INET]193.187.88.222:443 Apr 3 18:18:40 transmission openvpn[2811]: TCP connection established with [AF_INET]193.187.88.222:443 Apr 3 18:18:40 transmission openvpn[2811]: TCPv4_CLIENT link local: (not bound) Apr 3 18:18:40 transmission openvpn[2811]: TCPv4_CLIENT link remote: [AF_INET]193.187.88.222:443 Apr 3 18:18:40 transmission openvpn[2811]: TLS: Initial packet from [AF_INET]193.187.88.222:443, sid=193b0f69 18482e0f Apr 3 18:18:40 transmission openvpn[2811]: VERIFY OK: depth=1, C=SE, ST=CA, L=Stockholm, O=PrivateVPN, CN=PrivateVPN CA, name=PrivateVPN, emailAddress=support@privatvpn.se Apr 3 18:18:40 transmission openvpn[2811]: VERIFY KU OK Apr 3 18:18:40 transmission openvpn[2811]: Validating certificate extended key usage Apr 3 18:18:40 transmission openvpn[2811]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication Apr 3 18:18:40 transmission openvpn[2811]: VERIFY EKU OK Apr 3 18:18:40 transmission openvpn[2811]: VERIFY OK: depth=0, C=SE, ST=CA, L=Stockholm, O=PrivateVPN, CN=PrivateVPN, name=PrivateVPN, emailAddress=support@privatvpn.se Apr 3 18:18:40 transmission openvpn[2811]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bits RSA, signature: RSA-SHA256, peer temporary key: 253 bits X25519 Apr 3 18:18:40 transmission openvpn[2811]: [PrivateVPN] Peer Connection Initiated with [AF_INET]193.187.88.222:443 Apr 3 18:18:40 transmission openvpn[2811]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1 Apr 3 18:18:40 transmission openvpn[2811]: TLS: tls_multi_process: initial untrusted session promoted to trusted Apr 3 18:18:42 transmission openvpn[2811]: SENT CONTROL [PrivateVPN]: 'PUSH_REQUEST' (status=1) Apr 3 18:18:42 transmission openvpn[2811]: PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,sndbuf 524288,rcvbuf 524288,redirect-gateway def1,dhcp-option DISABLE-NBT,dhcp-option DNS 10.35.53.1,dhcp-option DNS 10.35.53.2,route-gateway 10.35.12.1,topology subnet,ping 20,ping-restart 60,ifconfig 10.35.12.6 255.255.254.0,peer-id 0,cipher AES-256-GCM' Apr 3 18:18:42 transmission openvpn[2811]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified Apr 3 18:18:42 transmission openvpn[2811]: Socket Buffers: R=[65700->524288] S=[33580->524288] Apr 3 18:18:42 transmission openvpn[2811]: OPTIONS IMPORT: --ifconfig/up options modified Apr 3 18:18:42 transmission openvpn[2811]: OPTIONS IMPORT: route options modified Apr 3 18:18:42 transmission openvpn[2811]: OPTIONS IMPORT: route-related options modified Apr 3 18:18:42 transmission openvpn[2811]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Apr 3 18:18:42 transmission openvpn[2811]: ROUTE_GATEWAY 172.16.0.1/255.255.255.252 IFACE=epair0b HWADDR=7e:c2:55:03:aa:47 Apr 3 18:18:42 transmission openvpn[2811]: TUN/TAP device /dev/tun0 opened Apr 3 18:18:42 transmission openvpn[2811]: /sbin/ifconfig tun0 10.35.12.6/23 mtu 1500 up Apr 3 18:18:42 transmission openvpn[2811]: /sbin/route add -net 193.187.88.222 172.16.0.1 255.255.255.255 Apr 3 18:18:42 transmission openvpn[2811]: /sbin/route add -net 0.0.0.0 10.35.12.1 128.0.0.0 Apr 3 18:18:42 transmission openvpn[2811]: /sbin/route add -net 128.0.0.0 10.35.12.1 128.0.0.0 Apr 3 18:18:42 transmission openvpn[2811]: Initialization Sequence Completed Apr 3 18:18:42 transmission openvpn[2811]: Data Channel: cipher 'AES-256-GCM', peer-id: 0, compression: 'stub' Apr 3 18:18:42 transmission openvpn[2811]: Timers: ping 20, ping-restart 60
