Plugin installation failed
skodik
Hi all,
I followed this guide for installing PlexMediaServer, but I run into some issues.
I try instal PlexMediaServer thru GUI, select plugins, PlexMediaServer and install it with default config. I am logged in as my root user. Installation fails on following:
[EFAULT] Exception: CallError:[EFAULT] pkg error: - pkg-static: /var/db/pkg wrong user or group ownership (expected 0/0 versus actual 1000/1000)
Can you give me some advice what I am doing wrong or what I forget to set up?
Thank you
It really would be best to reply on that thread--the chances of the thread starter or someone who knows that method better, seeing your question, are much higher. When you do, including the command you ran that resulted in that error, and some of the context surrounding it, would also be helpful.
