Plex Transcoder Blocked.
AstroZombie
I had a look at my logs and it seems like freenas blocking the plex transcoder from accessing files.
Any idea how to fix this?
Plex is running within a warden jail on 11.1 U4.
  • Plex Media Server Logs_2018-05-25_15-54-51.zip
kdragon75
You need to set the permission on the trans code folder so the Plex user has read/write access. If this is a mapped data-set, you may need to adjust the permissions on the data-set outside of your jail as well.
I don't recall all the details but if you search the forum you should be able to find a number of threads on the topic. HINT: In Google search 'site:forum.freenas.org "plex permissions" '
