Plex not finding server in web interface
CTbot
I recently upgraded to 11.2-RELEASE-U1, ever since that Plex has not worked. I decided to remove the Plex plugin and start over. The plugin installs and works only with DHCP, static fails each time. I can see the jail running and the IP is pingable. But the web interface is unable to see the server. Any ideas?
nojohnny101
CTbot
Upnp is enabled. I am running a Unifi network. I have also created a port forwarding rule on port 32400 in the Unifi firewall. No luck so far.
