Plex Issues
csearle
Hey Everyone I hope everyone is staying safe..
After updating to Truenas from Freenas, I was updating my Plex plug in manually. I went to go update the plugin recently with this Method
https://www.ceos3c.com/freenas/manually-update-plex-freenas/
but trunass retuned with cannot find website. So I deleted the Plex Plug in and updated it and set up plex again now some of my libraries won't show up in Plex, the Title library is there but no folder under that title won't show I have checked the permissions and every directory has proper permissions..
Did you have your library database (plex config/DB) outside the jail?
csearle
No i don't but before i had to leave for work I found the error some of the folder(s) are owed by the user and not Plex i'm hopping when I get back home I can resolve these issues
csearle
That didn't fix it for some reason any of my Tv Shows won't populate
So, without visibility of what you're saying isn't working, I can only lay out the important things and trust that you've checked them properly...
Permissions on Plex data, Plex config and Plex install directories/mounts in the jail
Matching those permissions to the user running plex (sysrc -a in the jail will show you plexmadiaserver_plexpass_user and group variables)
csearle
As seen in the screen Shots In my Disney Folder on plex, nothing shows up.. but in my directory in Media in the jail you can see I have several things showing.. I hope the clarifies
And the library is set to search in that path?
csearle
I will check again when I get home but i'm sure it is
csearle
Welp That was weird and just negligent on my part.. I went in to manage libraries and went into advance and went threw some of the options and found that switching from plex TV Scanner to TVBD fixed my issues
