avpullano
- Dec 30, 2012
I've been trying to expand my understanding of FreeNAS lately, so I hope this will spark some discussion.
I'm currently running 2x 2TB HDDs in a RAID1 configuration. I just bought a 3rd 2TB HDD so I can keep an offline backup. All 3 HDDs are of the exact same make and model. Now, since I bought the original 2 HDDs at the same time, they are likely from the same lot with similar manufacturing imperfections, etc. Therefore, deploying my backup plan will have 2 phases: (1) replacing one of the currently working HDDs with the new HDD & (2) regularly backing up the data from the RAID1 pool on FreeNAS to the offline HDD.
So, are there any major problems with my plan? Should I do some sort of regular maintenance on the offline backup (e.g. scrubs)? My desktop has an external 3.5" SATA bay, so adding and removing the HDD for backup or maintenance is not a problem, I just really like the idea of keeping a copy of my data completely inaccessible from anyone outside of my house (I've helped a friend through a Cryptolocker attack and you never know what sort of scams will come up in the future!).
- Seems simple enough. I plan on following the instructions for replacing a failed drive from the manual. I.e. taking one drive HDD, physically replacing it with the new HDD and resilvering. This will take a while for my ~800GB of data, but this is a home server so downtime is not a problem.
- This one seems a little trickier since there are more options for backing up. I think rsync will fit my needs, but all of the documentation in the FreeNAS manual refers to setting up a scheduled rsync. This is a home server, so I really only need to make a backup ~every 6 months and I plan on keeping the backup HDD completely offline (i.e. in a closet away from the FreeNAS box). Can I trigger an rsync manually or do I just have to enable an rsync each time I use it and then disable it when I'm done?
