camcontrol devlist glabel status
swapctl -a /dev/da0p1 /dev/da1p1 /dev/da2p1
zdb -luuu /dev/daXp2
zdb -e -uuuv storage zdb -e -h storage
gstat -I1s -f 'a?da[0-9]+$'
root@mfsbsd:/root # time zdb -e -bcsvL storage Traversing all blocks to verify checksums ... Segmentation fault (core dumped) 538.672u 185.228s 42:28.72 28.4% 84+2937k 13534329+0io 200pf+0w
root@mfsbsd:/root # camcontrol devlist
<ATA WDC WD20EARX-00P AB51> at scbus0 target 0 lun 0 (pass0,da0)
<ATA WDC WD20EARX-00P AB51> at scbus0 target 1 lun 0 (pass1,da1)
<ATA WDC WD20EARX-00P AB51> at scbus0 target 2 lun 0 (pass2,da2)
<ATA WDC WD20EARX-00P AB51> at scbus0 target 3 lun 0 (pass3,da3)
<ATA WDC WD20EARX-00P AB51> at scbus0 target 4 lun 0 (pass4,da4)
<ATA WDC WD20EARX-008 AB51> at scbus0 target 5 lun 0 (pass5,da5)
<SanDisk Extreme 0001>
root@mfsbsd:/root # glabel status
Name Status Components
ufsid/50ee738f6b8b4567 N/A md0
gptid/1aefa3e9-25fa-11e2-9ab0-00151736994a N/A da0p2
gptid/1c2d6a74-25fa-11e2-9ab0-00151736994a N/A da1p2
gptid/1b8f2b64-25fa-11e2-9ab0-00151736994a N/A da2p2
gptid/19a8970f-25fa-11e2-9ab0-00151736994a N/A da3p1
gptid/19b5ec3a-25fa-11e2-9ab0-00151736994a N/A da3p2
gptid/19097432-25fa-11e2-9ab0-00151736994a N/A da4p1
gptid/19177fb9-25fa-11e2-9ab0-00151736994a N/A da4p2
gptid/3db06e5a-3de6-11e2-8af1-00151736994a N/A da5p1
gptid/3dc2f956-3de6-11e2-8af1-00151736994a N/A da5p2
ufsid/50ee739507e96f49 N/A da6a
mkdir /var/zfs cd /var/zfs zdb -lu /dev/ada0p2 > ada0.uber zdb -lu /dev/ada1p2 > ada1.uber zdb -lu /dev/ada2p2 > ada2.uber zdb -lu /dev/ada3p2 > ada3.uber zdb -lu /dev/ada4p2 > ada4.uber zdb -lu /dev/ada5p2 > ada5.uber
Code:gptid/19a8970f-25fa-11e2-9ab0-00151736994a N/A da3p1 gptid/19097432-25fa-11e2-9ab0-00151736994a N/A da4p1 gptid/3db06e5a-3de6-11e2-8af1-00151736994a N/A da5p1
I also ran: swapctl -a /dev/da0p1 /dev/da1p1 /dev/da2p1
Code:zdb -luuu /dev/da0p2 > da0.uber zdb -luuu /dev/da1p2 > da1.uber zdb -luuu /dev/da2p2 > da2.uber zdb -luuu /dev/da3p2 > da3.uber zdb -luuu /dev/da4p2 > da4.uber zdb -luuu /dev/da5p2 > da5.uber
I believe that's because swap was already turned on for the first three drives.Strange, there's only swap partitions on the 3 above drives, instead of all of them.
root@mfsbsd:/var/zfs # zdb -e -uuuv storage
Uberblock:
magic = 0000000000bab10c
version = 28
txg = 735273
guid_sum = 15335734231262207449
timestamp = 1363313166 UTC = Fri Mar 15 02:06:06 2013
rootbp = DVA[0]=<0:5004f14c000:3000> DVA[1]=<0:33087645000:3000> DVA[2]=<0:6701aa1e000:3000> [L0 DMU objset] fletcher4 lzjb LE contiguous unique triple size=800L/200P birth=735273L/735273P fill=154 cksum=be6f62427:495d7c8f8f4:e74d2ea68fb4:1f153aea17e724
2012-11-14.19:15:42 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-14.19:15:42 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-14.19:29:11 [internal pool import txg:69270] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-14.19:29:11 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-14.19:29:11 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-14.19:51:28 [internal pool import txg:69515] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-14.19:51:28 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-14.19:51:28 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-14.20:47:18 [internal pool import txg:70170] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-14.20:47:18 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-14.20:47:18 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-15.21:10:04 [internal pool import txg:71992] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-15.21:10:04 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-15.21:10:04 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-15.21:34:17 [internal pool import txg:72267] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-15.21:34:17 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-15.21:34:17 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-15.21:56:00 [internal pool import txg:72512] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-15.21:56:00 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-15.21:56:00 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-16.21:55:54 [internal pool import txg:73714] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-16.21:55:55 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-16.21:55:55 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-17.09:35:44 [internal pool import txg:75511] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-17.09:35:44 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-17.09:35:44 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-17.17:40:23 [internal pool import txg:78132] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-17.17:40:23 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-17.17:40:23 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-18.21:25:03 [internal pool import txg:82937] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-18.21:25:03 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-18.21:25:03 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-19.20:23:47 [internal pool import txg:83939] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-19.20:23:47 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-19.20:23:47 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-20.17:01:54 [internal pool import txg:86146] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-20.17:01:54 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-20.17:01:54 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-21.21:15:29 [internal pool import txg:91574] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-21.21:15:29 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-21.21:15:29 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-22.17:14:59 [internal pool import txg:93434] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-22.17:14:59 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-22.17:14:59 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-25.21:41:30 [internal pool import txg:98014] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-25.21:41:30 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-25.21:41:30 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-26.17:33:03 [internal pool import txg:99104] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-26.17:33:04 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-26.17:33:04 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-27.07:56:42 [internal pool scrub txg:109520] func=1 mintxg=0 maxtxg=109520 2012-11-27.07:56:51 zpool scrub storage 2012-11-27.11:39:34 [internal pool scrub done txg:111629] complete=1 2012-11-28.16:52:50 [internal pool import txg:120305] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-28.16:52:50 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-28.16:52:50 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-28.19:49:25 zpool offline storage gptid/1a551ccf-25fa-11e2-9ab0-00151736994a 2012-11-29.06:46:48 [internal pool import txg:122445] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-29.06:46:49 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-29.06:46:49 zpool set cachefile=/data/zfs/zpool.cache storage 2012-11-29.06:52:16 [internal pool import txg:122485] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-11-29.06:52:16 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-11-29.06:52:16 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-03.15:51:20 [internal pool import txg:132764] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-03.15:51:20 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-03.15:51:20 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-03.15:59:08 [internal pool import txg:132839] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-03.15:59:08 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-03.15:59:08 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-03.17:59:33 [internal pool import txg:134207] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-03.17:59:33 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-03.17:59:33 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-03.18:12:49 [internal pool import txg:134345] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-03.18:12:49 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-03.18:12:49 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-03.18:31:22 [internal pool import txg:134553] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-03.18:31:22 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-03.18:31:22 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-03.18:55:47 zpool online storage 6201553240551106299 2012-12-03.18:56:40 zpool offline storage 6201553240551106299 2012-12-04.07:43:07 [internal pool scrub txg:144061] func=2 mintxg=3 maxtxg=144061 2012-12-04.07:43:18 [internal vdev attach txg:144063] replace vdev=/dev/gptid/3dc2f956-3de6-11e2-8af1-00151736994a for vdev=/dev/gptid/1a551ccf-25fa-11e2-9ab0-00151736994a 2012-12-04.07:43:18 zpool replace storage 6201553240551106299 gptid/3dc2f956-3de6-11e2-8af1-00151736994a 2012-12-04.11:05:45 [internal pool scrub done txg:145931] complete=1 2012-12-04.12:04:26 [internal pool import txg:146620] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-04.12:04:26 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-04.12:04:26 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-04.12:39:23 [internal vdev detach txg:147040] vdev=/dev/gptid/1a551ccf-25fa-11e2-9ab0-00151736994a 2012-12-04.12:39:23 zpool detach storage 6201553240551106299 2012-12-04.12:43:54 [internal pool import txg:147079] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-04.12:43:54 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-04.12:43:54 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-04.13:53:44 [internal pool scrub txg:147917] func=1 mintxg=0 maxtxg=147917 2012-12-04.13:53:52 zpool scrub storage 2012-12-04.17:23:19 [internal pool scrub done txg:149909] complete=1 2012-12-05.18:08:40 [internal pool import txg:153722] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-05.18:08:40 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-05.18:08:40 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-06.16:45:43 [internal pool import txg:157761] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-06.16:45:43 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-06.16:45:43 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-07.07:40:30 [internal pool import txg:163054] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-07.07:40:30 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-07.07:40:30 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-09.21:08:17 [internal pool import txg:192368] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-09.21:08:18 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-09.21:08:18 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-10.20:07:02 [internal pool import txg:200361] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-10.20:07:02 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-10.20:07:02 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-11.20:54:23 [internal pool import txg:202449] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-11.20:54:23 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-11.20:54:23 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-12.20:26:01 [internal pool import txg:204175] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-12.20:26:01 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-12.20:26:01 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-13.20:06:26 [internal pool import txg:206146] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-13.20:06:26 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-13.20:06:26 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-14.23:04:06 [internal pool import txg:207963] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-14.23:04:06 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-14.23:04:06 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-15.13:43:23 [internal pool import txg:208833] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-15.13:43:23 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-15.13:43:23 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-15.19:05:34 [internal pool import txg:212723] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-15.19:05:34 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-15.19:05:34 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-16.14:36:38 [internal pool import txg:216444] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-16.14:36:38 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-16.14:36:38 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-17.21:52:32 [internal pool import txg:222597] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-17.21:52:32 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-17.21:52:32 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-18.21:44:11 [internal pool import txg:223467] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-18.21:44:11 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-18.21:44:11 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-19.19:54:13 [internal pool import txg:224676] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-19.19:54:13 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-19.19:54:13 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-20.16:39:15 [internal pool import txg:227177] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-20.16:39:15 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-20.16:39:15 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-21.20:00:09 [internal pool import txg:232183] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-21.20:00:09 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-21.20:00:09 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-23.01:46:58 [internal pool import txg:235756] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-23.01:46:58 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-23.01:46:58 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-24.16:05:30 [internal pool import txg:251660] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-24.16:05:30 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-24.16:05:30 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-25.23:14:46 [internal pool import txg:257519] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-25.23:14:46 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-25.23:14:46 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-28.11:21:44 [internal pool import txg:300185] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2012-12-28.11:21:44 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2012-12-28.11:21:44 zpool set cachefile=/data/zfs/zpool.cache storage 2012-12-30.10:21:23 [internal pool scrub txg:334091] func=1 mintxg=0 maxtxg=334091 2012-12-30.10:21:31 zpool scrub storage 2012-12-30.14:10:44 [internal pool scrub done txg:336245] complete=1 2013-01-01.13:57:48 [internal pool import txg:378293] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-01.13:57:48 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-01.13:57:48 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-02.19:52:53 [internal pool import txg:387982] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-02.19:52:53 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-02.19:52:53 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-03.20:07:31 [internal pool import txg:392750] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-03.20:07:31 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-03.20:07:37 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-03.21:22:36 [internal pool import txg:394134] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-03.21:22:36 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-03.21:22:36 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-04.18:03:24 [internal pool import txg:396982] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-04.18:03:24 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-04.18:03:24 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-05.13:32:17 [internal pool import txg:421151] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-05.13:32:17 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-05.13:32:17 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-07.21:37:11 [internal pool import txg:446168] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-07.21:37:11 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-07.21:37:11 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-08.21:44:58 [internal pool import txg:447606] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-08.21:44:58 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-08.21:44:58 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-09.20:56:44 [internal pool import txg:449207] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-09.20:56:44 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-09.20:56:44 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-10.21:56:50 [internal pool import txg:450801] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-10.21:56:50 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-10.21:56:50 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-11.18:11:31 [internal pool import txg:452065] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-11.18:11:31 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-11.18:11:31 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-14.16:33:27 [internal pool import txg:495545] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-14.16:33:27 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-14.16:33:27 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.13:26:53 [internal pool import txg:496179] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.13:26:53 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.13:26:53 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.13:55:32 [internal pool import txg:496500] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.13:55:32 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.13:55:32 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.14:03:49 [internal pool import txg:496578] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.14:03:50 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.14:03:50 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.14:08:19 [internal pool import txg:496612] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.14:08:19 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.14:08:19 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.14:15:17 [internal pool import txg:496680] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.14:15:17 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.14:15:17 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.21:22:08 [internal pool import txg:496856] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.21:22:08 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.21:22:08 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-15.22:31:21 [internal pool import txg:497682] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-15.22:31:21 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-15.22:31:21 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-16.19:45:18 [internal pool import txg:498140] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-16.19:45:18 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-16.19:45:18 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-16.21:21:42 [internal pool import txg:499283] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-16.21:21:42 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-16.21:21:42 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-17.20:25:00 [internal pool import txg:500471] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-17.20:25:00 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-17.20:25:00 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-18.19:40:54 [internal pool import txg:501777] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-18.19:40:54 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-18.19:40:54 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-19.08:33:11 [internal pool import txg:504573] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-19.08:33:11 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-19.08:33:11 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-21.21:42:10 [internal pool import txg:532487] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-21.21:42:10 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-21.21:42:10 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-22.17:58:18 [internal pool import txg:533579] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-22.17:58:18 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-22.17:58:18 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-23.21:13:03 [internal pool import txg:542448] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-23.21:13:03 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-23.21:13:03 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-24.16:35:48 [internal pool import txg:543984] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-24.16:35:48 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-24.16:35:48 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-25.16:51:22 [internal pool import txg:548720] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-25.16:51:22 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-25.16:51:22 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-26.00:42:56 [internal pool scrub txg:554585] func=1 mintxg=0 maxtxg=554585 2013-01-26.00:43:04 zpool scrub storage 2013-01-26.04:30:00 [internal pool scrub done txg:556756] complete=1 2013-01-26.19:30:25 [internal pool import txg:567547] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-26.19:30:25 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-26.19:30:25 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-28.20:52:12 [internal pool import txg:587564] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-28.20:52:12 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-28.20:52:12 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-29.19:53:30 [internal pool import txg:588725] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-29.19:53:30 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-29.19:53:30 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-30.22:19:25 [internal pool import txg:591429] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-30.22:19:25 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-30.22:19:25 zpool set cachefile=/data/zfs/zpool.cache storage 2013-01-31.20:36:20 [internal pool import txg:592367] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-01-31.20:36:20 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-01-31.20:36:20 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-01.18:59:06 [internal pool import txg:594309] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-01.18:59:06 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-01.18:59:06 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-02.18:20:56 [internal pool import txg:607452] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-02.18:20:56 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-02.18:20:56 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-03.22:02:15 [internal pool import txg:610983] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-03.22:02:15 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-03.22:02:15 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-04.19:45:19 [internal pool import txg:611153] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-04.19:45:19 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-04.19:45:19 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-05.20:39:00 [internal pool import txg:613856] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-05.20:39:00 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-05.20:39:00 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-06.18:48:00 [internal pool import txg:616177] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-06.18:48:00 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-06.18:48:00 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-07.21:50:14 [internal pool import txg:618969] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-07.21:50:14 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-07.21:50:14 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-08.20:51:21 [internal pool import txg:619831] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-08.20:51:21 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-08.20:51:21 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-10.09:09:13 [internal pool import txg:622056] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-10.09:09:13 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-10.09:09:13 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-11.21:20:08 [internal pool import txg:632075] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-11.21:20:08 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-11.21:20:08 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-12.21:17:22 [internal pool import txg:633473] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-12.21:17:22 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-12.21:17:22 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-13.17:25:52 [internal pool import txg:634911] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-13.17:25:52 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-13.17:25:52 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-14.20:57:40 [internal pool import txg:639180] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-14.20:57:40 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-14.20:57:40 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-15.21:05:50 [internal pool import txg:639965] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-15.21:05:50 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-15.21:05:50 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-16.14:41:54 [internal pool import txg:641882] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-16.14:41:54 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-16.14:41:54 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-18.21:57:19 [internal pool import txg:665506] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-18.21:57:19 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-18.21:57:19 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-19.21:08:05 [internal pool import txg:666563] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-19.21:08:05 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-19.21:08:05 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-20.21:23:24 [internal pool import txg:668255] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-20.21:23:24 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-20.21:23:24 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-21.21:06:01 [internal pool import txg:669432] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-21.21:06:01 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-21.21:06:01 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-22.21:04:29 [internal pool import txg:671258] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-22.21:04:29 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-22.21:04:29 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-23.13:26:53 [internal pool import txg:673760] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-23.13:26:53 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-23.13:26:53 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-23.23:23:26 [internal pool scrub txg:680963] func=1 mintxg=0 maxtxg=680963 2013-02-23.23:23:34 zpool scrub storage 2013-02-24.03:13:57 [internal pool scrub done txg:683165] complete=1 2013-02-24.20:16:41 [internal pool import txg:687022] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-24.20:16:41 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-24.20:16:41 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-25.20:18:21 [internal pool import txg:689003] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-25.20:18:21 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-25.20:18:21 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-26.19:52:22 [internal pool import txg:691351] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-26.19:52:22 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-26.19:52:22 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-27.21:38:30 [internal pool import txg:693857] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-27.21:38:30 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-27.21:38:30 zpool set cachefile=/data/zfs/zpool.cache storage 2013-02-28.21:20:54 [internal pool import txg:695038] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-02-28.21:20:54 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-02-28.21:20:54 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-02.13:56:21 [internal pool import txg:697085] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-02.13:56:21 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-02.13:56:21 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-04.21:35:27 [internal pool import txg:721271] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-04.21:35:27 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-04.21:35:27 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-05.22:09:03 [internal pool import txg:722663] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-05.22:09:03 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-05.22:09:03 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-06.20:34:45 [internal pool import txg:723609] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-06.20:34:45 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-06.20:34:45 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-07.22:17:51 [internal pool import txg:725973] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-07.22:17:51 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-07.22:17:51 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-10.00:44:58 [internal pool import txg:727008] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-10.00:44:58 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-10.00:44:58 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-10.22:10:58 [internal pool import txg:727504] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-10.22:10:59 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-10.22:10:59 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-11.22:13:13 [internal pool import txg:728722] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-11.22:13:13 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-11.22:13:13 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-12.22:13:05 [internal pool import txg:729986] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-12.22:13:05 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-12.22:13:05 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-13.21:39:49 [internal pool import txg:731149] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-13.21:39:49 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-13.21:39:49 zpool set cachefile=/data/zfs/zpool.cache storage 2013-03-14.22:03:31 [internal pool import txg:732362] pool spa 28; zfs spa 28; zpl 5; uts 8.3-RELEASE-p4 803000 amd64 2013-03-14.22:03:31 zpool import -o cachefile=none -R /mnt -f 17472259698871586545 2013-03-14.22:03:31 zpool set cachefile=/data/zfs/zpool.cache storage root@mfsbsd:/var/zfs #
dT: 1.001s w: 1.000s filter: a?da[0-9]+$
L(q) ops/s r/s kBps ms/r w/s kBps ms/w %busy Name
0 0 0 0 0.0 0 0 0.0 0.0| da0
0 0 0 0 0.0 0 0 0.0 0.0| da1
0 0 0 0 0.0 0 0 0.0 0.0| da2
0 0 0 0 0.0 0 0 0.0 0.0| da3
0 0 0 0 0.0 0 0 0.0 0.0| da4
0 0 0 0 0.0 0 0 0.0 0.0| da5
0 0 0 0 0.0 0 0 0.0 0.0| da6
This should be sufficient.Command: zdb -e -h storage
Was to big for my screen, but below is a partial output.
Not yet.Not much happening...?
Give me a minute to look it over. You can run this in the meantime:If I run ' zdb -e -h storage' several times after each other, the percentages / numbers increase above for a short time, but nothing special imho? :S
sysctl vfs.zfs.debug sysctl vfs.zfs.recover
Give me a minute to look it over. You can run this in the meantime:Code:sysctl vfs.zfs.debug sysctl vfs.zfs.recover
root@mfsbsd:/var/zfs # sysctl vfs.zfs.debug vfs.zfs.debug: 1 root@mfsbsd:/var/zfs # sysctl vfs.zfs.recover vfs.zfs.recover: 1
Good, looks fine.Okay, thanks.
I ran the commands.
zpool import -T 735272 -o rdonly=on storage zpool status -v
3 1171 1171 76484 5.1 0 0 0.0 76.9| da0
10 965 965 61427 4.8 0 0 0.0 64.5| da1
10 1304 1304 102994 7.1 0 0 0.0 99.4| da2
10 1179 1179 83329 4.5 0 0 0.0 60.8| da3
10 971 971 63173 4.6 0 0 0.0 61.7| da4
10 1299 1299 77583 7.5 0 0 0.0 99.1| da5
That's the mfsBSD drive. It shouldn't have any activity.da6 is all the time 0% busy?!
9 1325 1325 58760 5.3 0 0 0.0 72.0| da0
4 719 719 66139 6.2 0 0 0.0 49.9| da1
9 1722 1722 91028 5.6 0 0 0.0 99.5| da2
8 1443 1443 65049 4.9 0 0 0.0 71.8| da3
9 497 497 56866 13.5 0 0 0.0 70.1| da4
7 1387 1387 62563 5.2 0 0 0.0 73.8| da5
Yeah sorry, I realised that after I posted it... :(
Drives still very active:
Code:dT: 1.001s w: 1.000s filter: a?da[0-9]+$ L(q) ops/s r/s kBps ms/r w/s kBps ms/w %busy Name 9 1325 1325 58760 5.3 0 0 0.0 72.0| da0 4 719 719 66139 6.2 0 0 0.0 49.9| da1 9 1722 1722 91028 5.6 0 0 0.0 99.5| da2 8 1443 1443 65049 4.9 0 0 0.0 71.8| da3 9 497 497 56866 13.5 0 0 0.0 70.1| da4 7 1387 1387 62563 5.2 0 0 0.0 73.8| da5 0 0 0 0 0.0 0 0 0.0 0.0| da6
da2 looks like it's a lot busier than the others though. Did you run and SMART tests on that?
10 658 658 52363 6.2 0 0 0.0 58.5| da0
10 1005 1005 63152 6.5 0 0 0.0 73.2| da1
10 1068 1068 88706 5.1 0 0 0.0 63.3| da2
9 1119 1119 82429 7.9 0 0 0.0 92.2| da3
10 922 922 56263 6.2 0 0 0.0 64.1| da4
10 693 693 87076 14.0 0 0 0.0 99.1| da5
Yes, if it was pegged the whole time that would be a symptom. As long as it's fluctuating like the other disks and e.g. the L(q) & ms/r are in range it's fine. Just keep an eye on the disks.And I think it doesn't matter, because it doesn't stay like that... It changes every 1 second.
root@mfsbsd:/var/zfs # zpool import -T 735272 -o rdonly=on storage cannot import 'storage': one or more devices is currently unavailable root@mfsbsd:/var/zfs # zpool status -v no pools available root@mfsbsd:/var/zfs #
