Tried to install few packages with pkg_add -r but it fails everytime..
Same happens with everything. My system is installed to usb stick.
freenas# pkg_add -r gdisk Fetching ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.2-release/Latest/gdisk.tbz... Done. Fetching ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.2-release/All/e2fsprogs-libuuid-1.41.14.tbz... Done. man/man1/uuidgen.1.gz: Failed to create dir 'man'Can't create 'man/man1/uuidgen.1.gz' man/man3/uuid.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid.3.gz' man/man3/uuid_clear.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_clear.3.gz' man/man3/uuid_compare.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_compare.3.gz' man/man3/uuid_copy.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_copy.3.gz' man/man3/uuid_generate.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_generate.3.gz' man/man3/uuid_is_null.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_is_null.3.gz' man/man3/uuid_parse.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_parse.3.gz' man/man3/uuid_time.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_time.3.gz' man/man3/uuid_unparse.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_unparse.3.gz' man/man3/uuid_generate_random.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_generate_random.3.gz' man/man3/uuid_generate_time.3.gz: Failed to create dir 'man'Can't create 'man/man3/uuid_generate_time.3.gz' man/man8/uuidd.8.gz: Failed to create dir 'man'Can't create 'man/man8/uuidd.8.gz' bin/uuidgen: Could not unlink include/uuid/uuid.h: Failed to create dir 'include/uuid'Can't create 'include/uuid/uuid.h' lib/libuuid.so.1.2: Could not unlink lib/libuuid.so.1: Could not unlink lib/libuuid.so: Could not unlink lib/libuuid.a: Could not unlink libdata/pkgconfig/uuid.pc: Could not unlink sbin/uuidd: Could not unlink tar: Error exit delayed from previous errors. pkg_add: extract_plist: can not invoke 544 byte tar pipeline: /usr/bin/tar cf - man/man1/uuidgen.1.gz man/man3/uuid.3.gz man/man3/uuid\_clear.3.gz man/man3/uuid\_compare.3.gz man/man3/uuid\_copy.3.gz man/man3/uuid\_generate.3.gz man/man3/uuid\_is\_null.3.gz man/man3/uuid\_parse.3.gz man/man3/uuid\_time.3.gz man/man3/uuid\_unparse.3.gz man/man3/uuid\_generate\_random.3.gz man/man3/uuid\_generate\_time.3.gz man/man8/uuidd.8.gz bin/uuidgen include/uuid/uuid.h lib/libuuid.so.1.2 lib/libuuid.so.1 lib/libuuid.so lib/libuuid.a libdata/pkgconfig/uuid.pc sbin/uuidd|/usr/bin/tar --unlink -xpPf - -C /usr/local pkg_add: pkg_add of dependency 'e2fsprogs-libuuid-1.41.14' failed!
