pkg setup
PeterFig
I bought a FreeNAS Mini box through Amazon. It seems pkg is set up like this:
Repositories:
  local: {
    url             : "file:///usr/ports/packages",
    enabled         : yes,
    priority        : 0
because of this:
[peter@freenas /usr/local/etc/pkg/repos]$ ls
FreeBSD.conf           local.conf             pcbsd-major.conf
[peter@freenas /usr/local/etc/pkg/repos]$ cat local.conf
local: {
    url: "file:///usr/ports/packages",
    enabled: yes
[peter@freenas /usr/local/etc/pkg/repos]$ cat FreeBSD.conf
FreeBSD: {
    enabled: no
[peter@freenas /usr/local/etc/pkg/repos]$ cat pcbsd-major.conf
pcbsd-major: {
    url: "http://pkg.cdn.pcbsd.org/10.0-RELEASE/amd64"
    signature_type: "fingerprints",
    enabled: false
Is there some reason (and does it matter) why this was configured this way?
Assuming I just need to add a suitable .conf file to this directory to update and install new packages, what should that .conf file look like?
You should not be using pkg on the base installation. If you want to install any additional software, that should be done in a jail.
Jailer
Not strong, but bad
Yeah, what they said. Install additional software in a jail or use the Virtualbox template and install in a VM.
Jailer
Not strong, but bad
If you want to play around with Docker on 9.10 you'll have to install your favorite flavor of Linux in Virtualbox.
