Physical space used, files inaccessible, zpool volume issues
Matt Rockell
Hi everyone,
Let me start by saying I am very new to FreeNAS and FreeBSD based operating systems in general. I've been looking around on the forums for a solution but I can't find anything that matches my particular issue (or at least I don't recognise that it does).
I have installed FreeNAS to have a central media centre instead of media files spread out over many machines. After I transferred a lot of files but before I really knew how to configure my FreeNAS effectively I made some changes to names and folder structures on my zpool and have since lost my ability to access about approx. 1TB of files.
I can see the physical space of the files is taken up but I can't access them. I would appreciate it if any of you could give me some insight. I've attached a text file which has some information about dataset labels and my zpool that may be useful.
Thanks in advance for any help or suggestions you can provide.
Cheers,
Matt
  • zpoolhistory.txt
paleoN
Output of the following, ideally from a SSH session as root using a wide window:
mount
zfs list
Use [code][/code] tags as they still help even in their current form.
It's probably a permissions problem.
Matt Rockell
Hi guys,
It's taken me a long time to get back to this issue i'm having. I actually am not that great with the command line stuff (I can easily follow instructions but am not very good with the creative problem solving bit!).
@paleoN: Could you please give me instructions on how to output the information you want?
Thanks, Matt
