PhotoStructure unable to mount data
nikkon
Hi folks,
I have troubles following the instruction to bind-mount my photo dataset to PhotoStructure.
The guideline says I need to mount everything under /ps/library
The problem is : it never deployes:
If I change the location to: /ps/library/ it works but I can't see anything in the app (however the mount works as I see the files from the container CLI)
Any guidance?
