Permissions to Nextcloud external storage HELP
Liquid
Hello there..
General Kenobi ;)
I have been searching the entire web for a fix on why my Nextcloud does not have permission to enter my mounted point, so here I am, hoping someone here can help me fix my problems.
So, I have 2 vdevs.
1 for jails
and one for storage.
I have installed nextcloud, and mounted this :
/mnt/Vault/NextCloud /mnt/Speed/iocage/jails/NextCloud/root/mnt/Nextcloud
on my dataset for NextCloud I have given user and group : www , Full access in the file information side, and ACL I have Full access given to @user , @group , webdav
yet, I am still not able to access the folder from nextcloud.
Nextcloud log says :
FatalwebdavOCA\DAV\Connector\Sabre\Exception\Forbidden: No read permissions
any help is very appreciated.
ChrisRJ
Congratulations. How did you fix it?
Liquid
I found out I had 2 folder inside the jail /mnt/ folder called nextcloud and another Nextcloud.
So just made a new mount to /mnt/cloud and that fixed it.
Think Nextcloud didn't know the difference on case sensitive folders.
